New dyno #s after AAM plenum spacer + other mods installed
Old Mar 26, 2005 | 05:27 PM
xziteme's Avatar
xziteme
Default New dyno #s after AAM plenum spacer + other mods installed
Just got the car dyno'd at the SOCAL dyno day in Huntington Beach. I gained 14rwhp after installing AAM plenum spacer, UR flywheel & pulleys, and Fuji Y-pipe.
Dyno #s before the new mods
Pre and post dyno's in one graph
Old Mar 27, 2005 | 07:32 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Nice gains, Im surprised with the Technosquare your running so rich up top...
Old Mar 27, 2005 | 06:27 PM
booger's Avatar
booger
Did TS make some timing adjustment TO ? The normal dip is almost gone in the after install dyno . I would say you got more from the timing adjustment than the spacer
Old Mar 27, 2005 | 11:40 PM
copba1t's Avatar
copba1t
Shouldn't opening up the intake/exhaust make you leaner? Looks like you got richer
Old Mar 30, 2005 | 06:11 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Lightbulb but...
okay now wait a minute, the way i'm reading the graphs, is that you're pretty lean just before 3k rpm. but the you steady out until around 4.2k rpm, then you start gettin' a little richer toward the ideal up until about 5.2k rpm, then you jus' get richer, and richer, and richer....well, you get the idea. since you got the reflash before all your other mods, you should probably take it back to TS to get another reflash. you should be able to give them your dyno-graphs (numbers would be better) and they should be able to go from there. you might wanna tell 'em to richen you up a little on the lower end. theoretically, if you hit 16, your car goes BOOM!
n1cK!
Old Mar 30, 2005 | 06:14 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
by the way, since you were at the dyno day on the 26th, you should post your results here.
n1cK!
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
