~!UPDATE!~ Headers anyone?
Old Nov 21, 2002 | 07:28 AM
  #61
Marv1000's Avatar
Marv1000
Originally posted by TJZ
Headers also have the ability for you to target the area of your powerband that you want to reshape by the design of the headers. 4-2-1 headers get most of their gains in the midrange, while 4-1 headers get most of their gains in the top end.
Correct me if I'm wrong, but isn't that for 4-cylinder applications (maybe each bank of a V8, too ... not sure)???
I thought those numbers referenced the exhaust from each cylinder, and how they joined on the headers. 4 cylinders up top joined into 2 and then one (which should hook up to your cat) ... or ... 4 cylinders that just all join into one pipe.
Each method gets you different results in your power band (power up top or at the bottom to mid-range).
I've never actually shopped for headers on a V6 before, so I have no clue what the lingo is!
Just curious ...
Old Nov 21, 2002 | 09:57 AM
  #62
krinkov's Avatar
krinkov
Good catch marv, your right
Old Nov 21, 2002 | 10:40 AM
  #63
dwnshift's Avatar
dwnshift
Turbo/supercharger issue................sounds fun but there alot of things with this car to take in consideration. The first thing is how the ECU will see it, and what it will do with the informationit reads.
Second is the fact that the diff will be a puddle on the pavement.
I love turbo's but....... going the all motor route I think might be a better choice here.
I have a S4 with downpipes exhaust and a chip. Lost one turbo and havent put the fun chip back in. got both of the turbos replaced under warranty (whew) Just my personal opinion on the matter though.
Old Nov 21, 2002 | 10:57 AM
  #64
roberto350z's Avatar
roberto350z
Originally posted by valuetl
Point taken BUT mark my words 30+ HP somewhere in the power curve on the dyno.
Old Nov 21, 2002 | 11:20 AM
  #65
krinkov's Avatar
krinkov
Also, nobodies taken into consideration how high the stock compression is, how much boost do you really think you will be able to put on top of 10.3/1 compression anyhow?
Old Nov 21, 2002 | 03:50 PM
  #66
TJZ's Avatar
TJZ
Compression isn't an issue. We can easily do 10 psi which would be worth some very nice gains. Unfortunately though, I think dwnshift is right to stay NA unless you have a lot of money to throw around.
Old Nov 21, 2002 | 03:52 PM
  #67
TJZ's Avatar
TJZ
Just curious ...
True, I guess Im just to familiar with i4's. Anyway if you look at it, it goes from 4 into 1. So couldn't you do the same thing and have them go from 4 into 2 into 1? If not, please explain.
Old Nov 21, 2002 | 04:40 PM
  #69
spf4000's Avatar
spf4000
Ummm...4 into 1? Please check the number of pipes. Three per side, correct? It's not an Integra with an I4, it's a 350Z with a V-6.
As for the guy that expects 30HP from just intake, headers and exhaust, you're in for a world of disappointment.
Old Nov 21, 2002 | 04:55 PM
  #71
TJZ's Avatar
TJZ
err...i know...i meant to ask if they make 3-2-1? Sorry, my knowledge of v-6-specific parts isn't quite up to par.
Old Nov 21, 2002 | 04:56 PM
  #72
TJZ's Avatar
TJZ
True.
Old Nov 21, 2002 | 07:33 PM
  #73
TJZ's Avatar
TJZ
Originally posted by VQracer
I'd say 10HP at the most. To the wheels.
Just a guess.
Victor
sounds about right, 10-15, judging by what dwnshift said.
B Esquire
Sep 24, 2015 07:52 AM
z33z_nutz
Sep 23, 2015 07:22 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
