Fluttering noise from exhaust?
A few weeks ago, my roommate and I installed Kinetix High-Flow Cats and Japtrix Y and B pipes on my 04. Since then, I've noticed a loud "fluttering" noise coming from under the car when under hard acceleration. I can't tell if the noise is coming from a certain side of the car. The noise...probably the best thing to compare it to would be a baseball card in the spokes of a bicycle. Just a rapid metallic fluttering noise. It only occurs at WOT, and is most noticable in 2nd and 3rd gear. Any ideas on this? It is a definite fluttering noise, not rasp or a hissing exhaust leak.
Any input would be appreciated.
From reading a previous thread, I'm thinking it may be the increased airflow as well. Some people were reporting a noise similar to the one that I've had after installing ONLY their test pipes or high-flow cats, and said that it was just the extra air passing through the pipes. I'm not sure I buy this theory though. I may just take my car to an exhaust shop some time soon and see what they have to say...
I have tried 2 different y-pipes now, both making some sort of increase. But I feel the the thickness of the tubing on the first pipe was to thin, causing the what you call a flutter. To me it was a resonating rasp inside the pipe readily heard inside the car. My current set up does not have the inside pipe rasp, but rather you can hear a little rasp in the upper rpm's out the tailpipes now.
Yes I had the same "flutter" sound with my 1st y-pipe/cat combo. I then when back to stock for a bit, only to really notice the "choke". I then added the Kinetix cats, stock y-pipe, and notice the "rasp" more but it seemed to fad once the car was warm. Now with the Gruppe S y-pipe the rasp never goes away, but it is only present above 3000 rpm, has a nice growl down low.. I have a set of Pro 1 headers to install next, we will see what happens then. I am thinking at this point my only hope is to tune the "rasp". My next step after headers may be a b-pipe with a good resonator, or try and replace the stock resonator with a glass pack, but not sure yet. One thing seems to be certain, stock cats control the "rasp".
Try swapping out parts until you find the one causing the problem. If still not found try removing the aluminum heat shields above both cats and maybe the one above the exhaust as well. It's a painful process but you're bound to find out what's doing it eventually.
Also, I don't know if the Kinetix cats have mounts for the OEM bracket, if not consider having some welded on to help absorb vibrations there.
Justin100
Nov 29, 2015 03:58 PM
acceleration, aftermarket, car, coming, corvette, engine, exhaust, flutter, fluttering, makes, noice, noise, resonator, sound, stock
