need help! got check engine light from intake
Old May 25, 2005 | 12:26 PM
bgairskier's Avatar
bgairskier
Default need help! got check engine light from intake
i installed an AEM cold air intake last night and when i started driving i got a CEL. when i got home i checked everything and it turns out the breather hose came off, so i figured it was that. so today i put a new hose clamp on there and it's on real good, but i still have the CEL. any suggestions?????
Old May 25, 2005 | 02:11 PM
jovasi's Avatar
jovasi
Try reseting your ECU.
Old May 25, 2005 | 02:12 PM
slaponte's Avatar
slaponte
Most cars reset the CEL after a few cold starts (like 3 or so) if you take care of the ofending problem. Or you can find somebody with a computer to turn it off...
Old May 25, 2005 | 02:13 PM
teh215's Avatar
teh215
Try this:
http://www.technosquareinc.com/350reset.htm
Old May 25, 2005 | 05:45 PM
onyx350z's Avatar
onyx350z
Just disconect the negative battery terminal for an hour or two and it should shut off. This is what Avalon racing told me to do and it worked.
Old May 25, 2005 | 07:48 PM
Z350Lover's Avatar
Z350Lover
btw... when you reset the ECU... do you reset everything in the computer? including the idle air volume control which sets your idling rpm (if nissan bumps it up already for ya for those light weight flywheel)?!
cheers,
richie
Uriyo_
Sep 8, 2021 08:46 AM
Fixxxercask
Nov 9, 2015 11:10 AM
Sleeper_Z
Sep 30, 2015 10:25 AM
