lower plenum only for 05 track?
Old May 28, 2005 | 05:54 PM
1sick350's Avatar
1sick350
Default lower plenum only for 05 track?
I was reading up on other forums on modds and found one that is a real bang for the buck. THe problem was when I went to the site it said 2005 track model. I found this to be strange. The item is $222 and gives an increase of 7-8 whp. It was proven on the dyno and supported by some owners. DOes it make sense that it would only fit 05s
Old May 28, 2005 | 07:27 PM
sentry65's Avatar
sentry65
the burninator
um
it fits all Z's
it loses major midrange power
it only gains some hp way up top - as in beyond the stock redline - so you'd have to get an ecu flash and be driving above 6500 rpms for it to be of any use
jason@performance nissan was going to go all out and set up his engine to rev to 8000 and abondoned the idea after deciding the 2005 lower plenum gains just aren't worth all that effort. So I wouldn't buy it.
Old May 28, 2005 | 08:48 PM
lowrider's Avatar
lowrider
Yep, that's right. I talked it over with Doug Stewart at Crawford. He tried it, and advised against it. Major looses in the low and mid range. It's designed to work with the variable controlled valves on the G35 6 speed, the "Z" track and the 35th 6 speed only.
Lou
Old May 29, 2005 | 09:26 AM
1sick350's Avatar
1sick350
so would it be better to go with the uper intake plenum instead?
Old May 29, 2005 | 09:47 AM
thawk408's Avatar
thawk408
Most definately.
Old May 31, 2005 | 05:21 AM
1sick350's Avatar
1sick350
Which of the plenums is best for hp gains?
Old May 31, 2005 | 05:32 AM
Losing Grip II's Avatar
Losing Grip II
CRAWFORD.
i have a crawford plenum (V5), powder coated black and crawford SB for sale if your interested, 350.00.
Kinetix makes an upper plenum but, unlike Crawford's, is plastic and has had a bumpy ride to being reliable. the goods about this plenum, however, VS crawford is that crawford requires removal of the stock strut bar and or buying their strut bar in place of the OEM peice.
john
btw: they also have FULL intake manifold which replace both the upper and lower plenums. Kinetix has just released one, i will post some pics once i have installed mine.
Old May 31, 2005 | 08:37 AM
thawk408's Avatar
thawk408
+1 for Crawford.
Old Aug 11, 2005 | 09:11 PM
bamyi's Avatar
bamyi
I'm in the market for one. How much hp can you gain and can you really feel the difference? I also saw that APS makes them now but I can't seem to find any torque or hp stats on these.
Old Aug 12, 2005 | 12:07 AM
sentry65's Avatar
sentry65
the burninator
do you have any other mods?
I didn't notice much from the crawford when I put it on my car when all I had was a jwt intake other than a different sound. I could pretend I felt a difference, but it just wasn't hugely apparent. It's supposed to gain about 8hp. They're only $350
if you want to stay cheap, get a spacer
Old Aug 12, 2005 | 04:01 AM
ZlleH's Avatar
ZlleH
What do you guys think of the motordyne spacers? Specifically the 1/4".
Old Aug 12, 2005 | 08:14 AM
lowrider's Avatar
lowrider
The Motordyne spacer, although it improves the lean condition suffered by the front cylinders due to the slant of the stock plenum, does not correct the basic problem. IMO, that problem is the mismatch between the air being fed to the front cylinders vs. the back. The Crawford plenum does attack this, and corrects for it.
+2 for Crawford.
Lou
Old Aug 12, 2005 | 10:33 AM
ZlleH's Avatar
ZlleH
But with the Crawford plenum you will lose the stock plenum cover and the stock struts bar?
+2 for Crawford.
Lou
Old Aug 12, 2005 | 12:29 PM
bamyi's Avatar
bamyi
I have a K&N cold air intake. I know that the gains varies depending on your mods and things but I'm just not sure if spending about $400 on a plenum is worth it. I'm thinking that I'm also gonna have to get a new chip to tune for the new airflow.
apex locator
Jul 23, 2021 02:27 AM
