Actually the design of the tube is sort of like the AEM V2 series intakes. The stated principle is the same as AEM's. It's just that WeaponR has such a bad rep, it's hard to take any of their products seriously.
I have seen these in person when Bozz had their open house. I would be surprised if it made as much power as stock. The innertube is held in place at each end by 3 standoffs with rivets that stick into the innertube. So we have restriction from the blunt edge of the innertube, the standoffs and the rivets. Add to this the fact that air slows down near the walls of a tube and there is 3 times as much wall because you have the inside inner tube, the outside inner tube, and the inside outer tube that air passes through. Essentially the flow may be closer to what you would get with just the innertube.
