Is the Kinetix SSV worth the money?
Old Jul 21, 2005 | 12:30 PM
HockeyZ39's Avatar
HockeyZ39
Default Is the Kinetix SSV worth the money?
I am debating on getting the Kinetix SSV or the Crawford Plenum. I am wondering if the SSV is worth the extra money, I am not planning on going FI. This, Crank Pully, and ECU reflash are my last planned speed MODS. Also If i went with the SSV I would invest in the Thermoshield Gaskets. Thanks in advance for any input and help!
Old Jul 21, 2005 | 12:42 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I think it's mostly for bling factor. Plus, I think I remember reading on the forum that people reported torque losses in lower RPM and gains only in higher RPMs.
sentry65's Avatar
sentry65
the burninator
I dunno, the people that have used it with NA so far have mostly said they think or feel like they've gained power over their crawford plenum.
I can't see it being more than 3-4whp more than crawford and 3-4whp is hard to feel so just how much can we believe them, I dunno
either way it looks cool, makes power for NA and saves weight
Some of us don't care about low torque loss. I never drive below 2000rpm's with my tilton clutch and am usually 2500rpm or higher 90% of the time anyway
Old Jul 21, 2005 | 01:50 PM
HockeyZ39's Avatar
HockeyZ39
The SSV does look real cool! But im not planning to make a showcar, and 400 dollars for looks where very few people will see doesnt make much sense to me! 3-4 hp isnt very impressive I was expecting alot more since it is SS (cooler air right?) and replaces upper and lowwer manifolds. Does any one have dyno charts with the cawford before and the SSV after??? Thanks again!
Old Jul 21, 2005 | 02:58 PM
sentry65's Avatar
sentry65
the burninator
no but people have dynos with the kinetix vs crawford
you'll have to look em up, don't know where they are off hand, but they're there. There's some threads on other forums as well with dynos
Almost all NA dyno charts had around a 4hp gain around 4000rpm, then another 4-5hp up top like 6300 and upward.
The rest of the dyno was pretty much even with the kinetix V4 with plus or minus 1hp here and there
I think there was a slight loss in power below 2000rpms (who cares)
and it always made the A/F much richer - like by .4 or so - NA or FI actually
this is all off my memory, might be slightly off
Old Jul 22, 2005 | 08:05 AM
zzzya's Avatar
zzzya
Looks is very subjective and if you haven't seen this in person I would be careful about the appearance factor and assuming it looks good. I personally think it looks like ****. With a very uneven look and all the runners off to one side. The other plenums can be polished as well. The SS build does not mean lower temps when compared to aluminum, this has been hashed out over and over. Also, be prepared to do some finishing work as many have had fitment and/or leakage issues required some work before the install is good. Gains are still under some question as tuning problems are there as well as timing of comparative dyno runs.
Old Jul 22, 2005 | 09:06 AM
HockeyZ39's Avatar
HockeyZ39
Well I have decided to go with the crawford Plenum. You cannot fit your stock strut bar over this Plenum right? Does any one know of a good aftermarket one that will fit and isint outrageously priced? Thanks for all the help guys! Or is there even really a difference when you take it off, is it just for show?
Old Jul 22, 2005 | 09:28 AM
sentry65's Avatar
sentry65
the burninator
you can fit the stock strut bar over the SSV
What I'm not sure is if you can use a thermogasket with the stock strut bar since it raises it a little
I was going to use my crawford strut or look into using the cusco strut bar since it's not as thick vertically
Old Jul 22, 2005 | 09:43 AM
HockeyZ39's Avatar
HockeyZ39
i just need somthing to fit over the craford pelum, the SSV is out of my mind now i dont want to get a strut bar that is to close either i have read about rattling and that would really tick me off!
Old Jul 22, 2005 | 09:50 AM
mcduck's Avatar
mcduck
Crawford makes a strutbar to go with their plenum.
Old Jul 22, 2005 | 10:33 AM
sentry65's Avatar
sentry65
the burninator
I think if you get an engine damper, it'll keep help the engine from hitting the strut bar
Old Jul 22, 2005 | 11:01 AM
frostyrock7c's Avatar
frostyrock7c
I had mine on with a Stillen eng. dampener and I had a slight rub when the engine got hot, but one set of washers under the strut bar mounting plates solved that problem. I loved my SSV, it made huge power at high RPM's but was barely noticeable at low RPM's. If you think about it, that is sort of a good thing, from 3500 up it comes alive, but it is still civil for street driving. I loved mine, the only flaw is that it takes a while to even out the A/F ratio. Looks great too. I think that it was worth it for me
Old Jul 22, 2005 | 11:09 AM
HockeyZ39's Avatar
HockeyZ39
Did you go from stock to the SSV? Or did you have the crawford first then upgraded?
Old Jul 22, 2005 | 11:15 AM
frostyrock7c
I went from stock to the SSV, but I have a friend that had the Crawford and he nooticed a difference. Pound for Pound, it really comes down to preference...the SSV is beautiful and can make big gains with proper tuning, the crawford is "tryed and true" but requires a different strut bar. I'm selling my SSV simply because I would rather use that money for race tires. I believe that Johanna1 is buying mine, but if not it will be up for sale again. Anyone interested if it falls through?
Old Jul 22, 2005 | 11:41 AM
HockeyZ39's Avatar
HockeyZ39
I dont plan to go to much further with my tuning. I have CAI, cat back, and test pipes so far. I plan to get the plenum (or the SSV) with a crank pully and a reflash to finish it off. The SSV wouldnt give but a few more HP over the crawford in this set up correct? I dont see spending 450+ more dollars for a minimal amount of hp as a sound investment, but correct me if i am wrong, which happens quite a bit!
Old Jul 22, 2005 | 11:52 AM
Road Warrior's Avatar
Road Warrior
you have to either get the crawford or stillen strut bar if you go with the crawford plenum....i personally like the look of the crawford strut bar vs the stillen strut bar.
Old Jul 22, 2005 | 11:58 AM
sentry65's Avatar
sentry65
the burninator
or the APS bar...
Old Jul 22, 2005 | 12:08 PM
Road Warrior
Originally Posted by sentry65
or the APS bar...
haven't seen the aps...do you have a link or pics? tx
Old Jul 22, 2005 | 12:23 PM
sentry65's Avatar
sentry65
the burninator
http://www.airpowersystems.com/350z/...trut_brace.htm
Old Jul 22, 2005 | 01:25 PM
Road Warrior
wow....thats nice!
i wish i had seen that before i bought my crawford....that looks really cool
it also appears that aps has their own plenum....anyone know how the aps compares to the crawford?
thanks for the info sentry65
rw....peace out
