APEX'i power intake
Old Dec 7, 2006 | 07:42 AM
tranceformer95's Avatar
tranceformer95
Originally Posted by plumpzz
dont want to burst ur bubble but the popcharger doens't use a universal adapter . It connects directly toe the maf via 4 bolts. Universals have a pipe that has a 3 or 2.75 inch inlet.
Actually i think the MAS tube attaches to the venturi plate, with 4 bolts and then the filter slips over that plate with a hose clamp. So i guess all you need to do is measure that outer diamted and match it to a filter.
Old Dec 7, 2006 | 08:44 AM
three_fitty's Avatar
three_fitty
JWT has a 6" cone opening, with Apexi, i believe max is 3.75". Trust me, its not worth the hassle.
Old Dec 7, 2006 | 08:59 AM
97supratt's Avatar
97supratt
Yup I agree. The velocity stack on the JWT is much bigger than the Apexi.
Old Dec 7, 2006 | 09:07 AM
dvo's Avatar
dvo
I actually just bought one. I needed a new filter for my nismo intake because the metal "mesh" around it is a little damaged. i also just wanted to try something different. i've yet to put it on though. I'll post some pics when i do though.
Old Dec 7, 2006 | 10:34 AM
97supratt's Avatar
97supratt
+1 on the pics.
Old Jan 12, 2007 | 12:03 PM
Citrus's Avatar
Citrus
Check the DIY engine section for pics and write up. I have an Apexi power intake setup. The velocity stacks are inside the filter are are the diameter of the entire lower filter portion, probably very much the same size as the JWT poop charger. Apexi does an adequate (better than most japanese brands) job of filtration and flow and I don't risk getting oil on any sensors.
apex locator
Jul 23, 2021 02:27 AM
codek
Sep 28, 2015 03:03 AM
