mine stalled last night.....i went to 120mph and when i went to slow down, i think i press the clutch to put my car into neutral and my engine quit out on me.....it was scary too cause i had no power steering or power brakes......
That was God's way of punishing you for going so fast
The MAF is really sensitive..just unplug the battery for a bit and itll fix. When i installed it, i unplugged battery. Its safe to say you should unplug the battery and hold the brake for like 10 seconds after you unplug to drain all power in capasitors prior to doing any upgrade.
What is the benefit of resetting the ECU? I installed the jwt without resetting the ecu and it works just fine. Can someone please tell me what the positive outcome of doing this...
