Pros/Cons: True Dual vs. Y-pipe cat back
Old Sep 6, 2005 | 06:58 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default Pros/Cons: True Dual vs. Y-pipe cat back
What are the pros and cons of having either a true dual setup or catback with y-pipe? I will be going all NA, if that makes any difference. Any advice would be appreciated.
Old Sep 6, 2005 | 10:19 PM
Z BOY's Avatar
Z BOY
i've seen it posted that with na, you want some back pressure for low end torque, hence, you want less flow. with fi, back pressure is the enemy. i'm just posting what i've read on this site.
check out this article:
www.cobbtuning.com/tech/exhaustdesign/index.html
Old Sep 6, 2005 | 10:53 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Exactly!
Old Sep 7, 2005 | 06:16 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
That site does not say you want or need backpressure, it says...
"One thing I do want to explain before I get too far into this is backpressure. I hear "You need backpressure to make torque." all the time. And it even comes from "tuners" as well as customers. This is flat out not true. Before I arrived into the company of true tuners I fell into the same trap myself. The reality is that backpressure is the enemy. You want to keep it as low as possible. What you do want is to keep velocity up. However doing the things that keep velocity high involves slightly more backpressure under some conditions. You want to keep the gasses moving as quickly as possible to make both good torque and top end power. The perfect exhaust system would keep the gasses moving as fast as they did coming out of the cylinder and have zero backpressure. However this is impossible to achieve in the real world."
Please don't spread the backpressure myth.
Chris
Old Sep 7, 2005 | 06:20 AM
HyperSprite
Mad Scientist
Not all Y pipe and true duals are created equal, you can't really have a general "what's better" when some true duals run small pipe and no crossovers others run crossovers with larger pipe. Y pipe systems have various configurations too.
The only consistent thing to compare is that a Y pipe system usually has less parts and that is neither here nor there once it's all installed.
Chris
Old Sep 7, 2005 | 06:36 AM
Thumbs up Thanks.
Chris
I’d like all forum members to read Exhaust 101 about the relationship between exhaust volume, exhaust velocity, horsepower and torque. But I suppose that this will be a never ending subject like “What is the best intake?”
Old Sep 7, 2005 | 08:25 AM
USMC-Z's Avatar
USMC-Z
Z Veteran
The backpressure issue was exactly why I asked this question. I've heard that backpressure is good for an NA car. I'm trying to make a decision to get wider piping (a new exhaust) over the stock. So far for my exhaust, I have test pipes and will be installing headers shortly. Will an exhaust with more or less backpressure be beneficial in my setup?
Old Sep 7, 2005 | 05:43 PM
kzshin's Avatar
kzshin
Finally, somone who know's what he's talking about. + 1 to HyperSprite.
Old Sep 7, 2005 | 07:08 PM
Triple8Sol's Avatar
Triple8Sol
Chris
I'm glad you beat me to it and killed that stupid myth, in this thread, at least...
Uriyo_
Sep 8, 2021 08:46 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Apr 28, 2017 09:00 PM
