Crawford upgrades. What to expect?
Old Sep 12, 2005 | 10:46 AM
BluZee's Avatar
BluZee
Default Crawford upgrades. What to expect?
What can I realistically expect from the entire Crawford package (throttle body, plenum, headers, cats) with a reflash to go with it? I already have a pop charger and Injen exhaust.
Old Sep 12, 2005 | 10:55 AM
sentry65's Avatar
sentry65
the burninator
about 15-23-ish whp
Old Sep 12, 2005 | 11:03 AM
lowrider's Avatar
lowrider
Look Here:
https://my350z.com/forum/intake-exhaust/130789-my-crawford-headers-came.html
Lou
Old Sep 12, 2005 | 11:10 AM
BluZee's Avatar
BluZee
Originally Posted by lowrider
Did you have any baseline numbers to compare with? Plus, how much of a difference do you think it would have made if you had the throttle body also?
Thanks
Old Sep 13, 2005 | 04:52 AM
lowrider's Avatar
lowrider
Sorry
The only Baseline is the other "G" with the RevUp engine. As far as TB Mods go, I don't know what you have in mind. My Butterfly was modded to open all the way when I had my ECU flashed. With the ECU change, I did get a higher Red Line, other than that I didn't notice much difference.
Lou
Old Sep 13, 2005 | 03:48 PM
BluZee's Avatar
BluZee
Crawford sells a throttle body now.
Old Sep 13, 2005 | 06:30 PM
ZPirate's Avatar
ZPirate
Approximately 20 whp. According to Doug the throttle body will give you more power if you have or plan to install cams. Otherwise the throttle body only gives you one or two addtional horsepower.
Old Sep 13, 2005 | 08:05 PM
thawk408's Avatar
thawk408
Wounder how well it would work with the new cams in the 300hp motor.
Old Sep 14, 2005 | 04:06 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
From what we've seen, upgrades such as the plenums, and headers etc.. work very well on the rev up 300hp motor. These engines benefit more from plenum upgrades than the previous engines. It's all about how the motor is designed and where the motor makes its power....
Old Sep 14, 2005 | 04:53 PM
zzzya's Avatar
zzzya
I would guess around 20 peak rwhp, with the real gains comming throughout the midrange making the car a lot more responsive and fun to drive. I would hold off on the ECU reflash at this time. It will not be worth the money if you end up going with cams later, plus there are now some better alternatives for timing and A/F tuning such as the Greddy Emange Ultimate. If you do get a reflash I would only recommend the Limited Spec flash which fixes the TB opening, increases the rev limiter and removes the speed limiter.
Old Sep 14, 2005 | 05:51 PM
Badmonkey's Avatar
Badmonkey
What, if any, gains could one expect with the larger throttle body and a supercharger? I am pushing 400rwhp now and wonder if the upgrade would be worth it.
Old Sep 15, 2005 | 07:06 AM
BluZee's Avatar
BluZee
Thats a reason why I wanted the reflash to begin with.
Old Sep 15, 2005 | 07:27 AM
thawk408's Avatar
thawk408
It talked to AAM and they said that the throttle body opening thing is not true. They said that if you have a pooring reading machine then it will only say 80%. But it opens 100% from the factory.
Old Sep 15, 2005 | 07:32 AM
G I Love My Car's Avatar
G I Love My Car
Skip the reflash and go Greddy Emanage Ultimate. Way more tunable and you can get your A/F dead nuts on. I promise you cant do that with TS Flash
Old Sep 15, 2005 | 07:59 AM
thawk408's Avatar
thawk408
Can the emanage ultimate adjust cam timing? I don't think it can, but I know the reflash can.
Old Sep 15, 2005 | 08:09 AM
Badmonkey's Avatar
Badmonkey
No cam timing, just ignition timing.
Old Sep 15, 2005 | 08:14 AM
D350Z10's Avatar
D350Z10
The crawford headers were the best mod i ever bought, car is crazy fast, on the G-tech timer i ran a 12.80 1/4 with a 2.0 60 @ 109 mph ft on the street!!!!
mods
Greddy Evo 2
helix test pipes
crawford headers
Crawford plenum
injen intake
unorthodox pulley kit
greddy emanage fuel comp tuned
grounding kit
crawford strut bar
B&M short throw shifter
nismo lmgt4 wheels with bfgoodrich ta k/d 275
light weight- 3100
Old Sep 15, 2005 | 09:41 AM
G I Love My Car
D350 what is your wheel hp with all your mods?
Old Sep 15, 2005 | 03:48 PM
zzzya's Avatar
zzzya
Cam timing can be adjusted with the reflash but not the EU. There is some work being done right now with a Motec setup to learn more about the effects of adjusting cam timing on our engines. It may be the key to the 300+ rwhp barrier.
Old Sep 15, 2005 | 03:54 PM
D350Z10's Avatar
D350Z10
My rwhp is 285 at 6350 rpms, hopefully with the techno square ecu flash i will be at 300!
