in one day my exhaust seems louder even after 10k breakin?? leak?? fiberglass problem
Old Sep 14, 2005 | 06:58 PM
seanlaw's Avatar
seanlaw
Default in one day my exhaust seems louder even after 10k breakin?? leak?? fiberglass problem
today after driving home from the train station it seemed my car lost torque in the low range, my exhaust got extremely louder, deeper and less poppy. i'm pretty sure i've broken in my injen since i've had it for a year w/ 10k miles. the test pipes i put on about 5k miles ago and i keep throwing fiberglass like a freakin fire extinquisher.
is it possible that:
1. the last chunk of fiberglass blew out today?
2. i have a serious leak somewhere?
3. the test pipes ruined my funked injen straight tip with the fiberglass problem?
someone chime in with this same setup (injen, helix)...thanks
Old Sep 14, 2005 | 07:07 PM
The rear of my white Z has some black specs on it from the exhaust. Not sufficient to cause a problem. Search for a leak. If none found, and you're still not content, have a diagnostics test run.
Old Sep 14, 2005 | 07:10 PM
seanlaw's Avatar
seanlaw
most leak posts have concerns with a 'hiss'...i don't seem to have that problem
Old Sep 20, 2005 | 07:44 PM
drumma022's Avatar
drumma022
I got a leak today and found that the 2 y-pipe bols were a bit loose and blew out the gasket. There was no hissing noise, just MUCH louder exhaust tone and more rasp from the test pipes.
Old Sep 20, 2005 | 08:00 PM
Nismo 350z's Avatar
Nismo 350z
which exhaust system do u have?
Old Sep 21, 2005 | 08:08 AM
drumma022's Avatar
drumma022
JIC Y-pipe and Exhaust system.
Old Sep 21, 2005 | 05:50 PM
Nismo 350z's Avatar
Nismo 350z
drumma i was asking seanlaw. lol anyways check for a leak or maybe the test pipes have a crack in them. look for a blown gasket seal. if everything is fine then run a diagnostic test. if that says ur car is ok then i dunno....
Old Sep 22, 2005 | 04:54 AM
seanlaw's Avatar
seanlaw
thanks guys...i'm going to check all the bolts first, then check the gaskets, the check the welds on the test pipes.
Chris350z03
Oct 8, 2023 07:19 PM
StateNuke08
Oct 31, 2015 05:01 AM
dcains
Sep 21, 2015 09:28 AM
Bigsyke
Sep 11, 2015 06:19 PM
PureR3d
Sep 10, 2015 06:23 PM
