Motordyne Iso Thermal Plenum Spacers
Old Sep 16, 2005 | 10:37 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Originally Posted by 35ounces
when does this GB start/end and details for signing up?
I'm making preparations for it now. It should start in the next week or two.
Old Sep 16, 2005 | 10:44 AM
gatti-man's Avatar
gatti-man
are we going to see dyno numbers before the GB?
Old Sep 16, 2005 | 10:53 AM
Hydrazine's Avatar
Hydrazine
The MD spacer dynos will be published in the next issue of Sport Z Magazine. You will definitely want to get a copy of it!
Old Sep 16, 2005 | 11:02 AM
Z BOY's Avatar
Z BOY
ok, sign me up for the isothermal upgrade without the spacer or copper tb warmer, when gb starts.
Old Sep 16, 2005 | 11:04 AM
the7ferret's Avatar
the7ferret
Sign me up for Package #1 Gasket w/o Copper TB plate, when the group buy starts...
Old Sep 17, 2005 | 09:47 AM
badmrscary's Avatar
badmrscary
I'm on for a BG#6.
Old Sep 17, 2005 | 10:12 AM
corsair's Avatar
corsair
Looking good. Can't wait for the official group buy thread to be posted.
Old Sep 17, 2005 | 01:56 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
please explain the copper isothermal option again... how does this dramatically decrease the temps?...i would assume the coolant still flows through the throttle body, this gasket is used to keep some of that heat away from transferring into the plenum, right? if so, the valve would be a better option, only one would have to monitor its position accordingly for weather...
also, the 1/2 plenum spacer...does this work with the stock strut tower bar with an icreased strut tower bar spacer? (or are the studs that fit into the stock strut tower brace not tall enough?)...
I think i'm in for #7...when will the GB begin?
Thx
TODD
Old Sep 17, 2005 | 09:11 PM
Z BOY's Avatar
Z BOY
Thx
TODD
actually, if you read his description again, the copper bit keeps the tb WARM in regions of cold ambient temps so it doesn't freeze shut in freezing weather.
Also, the 1/2" spacer doesn't accommodate the stock strut bar. the 5/16" does.
Old Sep 17, 2005 | 10:39 PM
anotheraznguy's Avatar
anotheraznguy
ok i am sooo lost right now...
the 5/16 will clear the strut...
now.... i live in cali..
stock setup..
what is the best setup for me?
Old Sep 17, 2005 | 10:58 PM
Z BOY's Avatar
Z BOY
stock setup..
if you want to keep your stock strut bar and don't live where it freezes, get the 5/16 spacer. i think it now comes with the new isothermal gasket that goes btwn the lower plenum and intake manifold. if you want more air intake and are willing to lose the stock sb, get the 1/2. if you live where it freezes, get the copper thingy throttle body upgrade.
Old Sep 18, 2005 | 06:36 AM
Hydrazine's Avatar
Hydrazine
+1 like Matt said.
Get the 5/16" Iso Thermal plenum spacer (no copper). If you drive to Montana in the winter get the Copper TB heater, otherwise it just doesn't get cold often enough in Ca to mandate the Copper.
The Copper TB heater is neat little device though. That thing really works!
When you put it on, the TB is clearly hot and the Plenum is clearly cool...
Old Sep 18, 2005 | 07:28 AM
baileyrx's Avatar
baileyrx
i'm in!! thermal iso plus the copper thingy. just waiting for the g.b.
supercharged & in NC (sometimes cold)
Old Sep 18, 2005 | 07:31 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
Great addition to the Motordyne Engineering product line!
I'm sure the drag, road, and autocross 350Z/G35 racers will appreciate these modifications. (lowering temperatures (prevents heat soak from happening as quick as it did before) and adding power (by increasing airflow))
Old Sep 18, 2005 | 08:32 AM
freezeg35's Avatar
freezeg35
So bang for the buck should i be looking at this over the cast crawford plenum???
Old Sep 18, 2005 | 08:56 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Thx
TODD
please answer this question...
Old Sep 18, 2005 | 08:58 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
so u plug the coolant line completely, and the copper acts to tranfer heat to the throttle body at all times...hmmm..has the throttle body temp been measured with the copper vs the coolant temp?
(i know it wouldnt take much heat to prevent it from freezing-any other implication for the coolant line through there?)
Old Sep 18, 2005 | 09:45 AM
  #38
taurran's Avatar
taurran
I think I'll be down for the group buy. I'm still trying to decide on what size spacer to go with, depending on if the strut bar will fit on the 1/2".
If the stock strut doesn't fit with this spacer, I'm guessing I can go with the Crawford or APS strut bars?
Old Sep 18, 2005 | 09:46 AM
  #39
Hydrazine's Avatar
Hydrazine
If you only did it for the "bang", the answer is Yes.
If you only did it for the "buck", the answer is Yes.
If you only did it "bang for the buck", the answer is Yes x 2.
I know that must have pushed some buttons out there.
Thats the one question that will always stir up a fire storm, but if the question is asked, I must answer truthfully.
Putting on flame suit now!
Old Sep 18, 2005 | 10:08 AM
  #40
Hydrazine's Avatar
Hydrazine
Although it is not required, it can be done if the hood spacers are used. Most people won't like the look of hood spacers so they are left as an optional item for installation. The hood spacers are a purely functional item that is ideal for tracking or while at the strip. In addition to letting you put on the stock strut bar, the hood spacers blast very large volumes of cool air through the entire engine compartment. When racing, anything that brings down engine compartment temperatures is a good thing.
G35's don't have a strut bar, but I use the hood spacers when tracking.
