stillen exhaust + loose bottem end torque?
Hello,
I am worried if I get the stillen dual exhaust, I will loose some bottem end torque but game some higher end hp, is this correct? What of gains/losses can I expect? Just want to be sure before I drop $1000 for it.
Thanks a lot,
Flash
Thanks a lot,
Flash
rule of thumb:
dual exhaust = lose power low to get more up high
cat-back = dont lose much/any down low, but only make half the gains up top
it doesnt always work like this.....but generally this is what i gather from the 8 bajillion threads about this
Originally Posted by flashv2
Hello,
Thanks a lot,
Flash
Thanks a lot,
Flash
During the Sport Z Magazine exhaust shoot out, Nismo was the only exhaust that did not loose any torque & hp at low rpm.
Plus its cheaper and with the money you save with Nismo, get JWT Pop charger. With those two mods I'm sure you will you will have more hp & torque.
Stillen was over all a very good exhaust in term of hp & torque gain.
One more thing, if you want deep low noise, go with Stillen but if you like stock exhaust troaty sound but louder, go with Nismo.
Hello,
Thanks a lot,
Flash
Thanks a lot,
Flash
IMHO it sounds great too!
Originally Posted by ssk0771
If you don't want to loose low end torque, go with Nismo.
If you care to check out all the dyno charts and peak numbers you'll see Stillen's Exhaust made more across the board torque and hp, and more peak torque than any of the other systems. It made 22.23% more peak HP and 38.36% more peak torque than the Nismo. It lost the peak horsepower race to to Borla by 1.22% but made 63.02% more peak torque than the Borla.
The Nismo system did beat the Stillen exhaust in two areas. It was 20# lighter and two db louder at 3k rpm.
Originally Posted by DaveO
While I personally like both the Nismo and Stillen 350Z exhaust systems, I sure wish the famous Sport Z Magazine Exhaust Shootout dyno sheets were available on line. After re-checking them in the Fall 2003 Issue I must respectfully disagree with your statement "Nismo was the only exhaust that did not loose any torque & hp at low rpm."
I'm sure you're aware that dyno readings below 2k aren't normally used as they're often unreliable. However if you look real carefully at the Nismo results you'll see it lost a very slight amount of torque in the 1.9K to 2.1k rpm range.
If you care to check out all the dyno charts and peak numbers you'll see Stillen's Exhaust made more across the board torque and hp, and more peak torque than any of the other systems. It made 22.23% more HP and 38.36% more torque than the Nismo. It lost the peak horsepower race to to Borla by 1.22% but made 63.02% more torque than the Borla.
Also, I NEVER SAID that Nismos beat Stillen in performance nor mention that Nismo made most torque & hp. I was just informing "flashv2" because he was concerned about loosing torque at low end. I am aware of the hp/torque number of Stillen. I also know that Stillen was one of the best performing exhaust in term of hp/torque during the exhaust shoot out. Stillen was very well balance between torque & hp unlike Borla which had real good gain in hp but produced very little torque.
Also you are using % in terms of gain which seems like a lot but in terms of real number, its not very much.
Stillen: 8 HP w/6lbs gain in torque. Stillen states 16hp gain & 14lbs in torque.
Nismo: 6 HP w/3.5lbs gain in torque. Nismo states 6hp gain & 3.5lbs in torque.
Those number are not that significant.
Between Nismo & Stillen, Just like you, I like both but for the price of Stillen Exhaust, you can get both Nismo Exhaust & JWT Pop Charger and have money left over for Intensepower.com Resonate Race Pipe.
I'm sure that with Nismo Exhaust + JWT Pop Charger + Resonate Race Pipe, you will have better number in both hp & torque than Stillen Exhaust alone.
Stillen Exhaust: $1150 www.mynismo.com & www.stillen.com
Nismo exhaust:$880 at www.nissanparts247.com
JWT Pop Charger:$120 at www.mynismo.com
Intensepower.com Resonate Race Pipe:$149 at www.intensepower.com
=Total $1149
That about same as Stillen Exhaust alone.
Any change in the intake or exhaust system will alter the torque curve. You may be able to fine tune the curve to your liking with a custom ECU programming.
Most drivers are interested in maximum horsepower at red line. You can tune for low end torque, or you can tune for maximum horsepower, but its difficult to tune for both.
You may be right. I really did not look at the Dyno chart very closely. What I really meant to say was that Nismo had least amount of hp/torque loss at low rpm amongst all the exhaust that was tested. Unless you look at the dyno chart very closely, its hard to see that the loss with Nismo at low end.
=Total $1149
=Total $1149
As for pricing, at the time the article was published the price of the Nismo system was $1100 and a dealer had to install it if you wanted the "3-year - 3.6k mile factory warranty". Stillen's was $1150 and came with a limited lifetime warranty.
An article in the December 04 Turbo Magazine also tested Stillen's Exhaust and said it made "twice the power of any other 350Z system we ever tested..." (about 14 hp).
You don't buy an exhaust merely on power increases alone. You should also look into how it is constructed, the type of flanges used, pipe orientation, and overall fitment. I've heard nothing but praise from people who have installed the Stillen system. Everyone says it fits like a glove. The Borla has had issues with hanger orientation alowing the passenger side pipe to hit the underbody.
Don't worry about the weight difference. 20lbs will NEVER be noticed.
sean
sean
Originally Posted by HarvesterUT
rule of thumb:
All these numbers are hype.
sean
sean
For some reason, you can find a good deal on Nismo Exhaust but not Stillen, the lowest I seen was $1150.
I currently have Stillen myself and I like it. I paid $1150 2 years ago when I had Silver 350Z Coupe.
Just one thing about Stillen. Once you put them on, its a real b!tch to take it off.
I found this out when I was switching exhaust from coupe to the roadster.
It took muffer shop over 2 hours.
Finally, a voice of reason. Go Speedracer, gooooo!
Originally Posted by Speedracer
When will this misinformation end! Dual exhaust does not produce more power anywhere, anytime than a properly designed single exhaust. I dare someone to properly explain the physics of how it does. They can't! Because it doesn't!!!! Also, any test results that are not consistently reproducible are worthless. I'm not saying that Stillen is better than Nismo or vice versa, just don't assume any data to be true unless it is consistently reproducible. There are far too many variables to give statistical significance to a 2hp difference in a single dyno test on different cars, at different times, with different temperature conditions, etc. Anyone who has had their car dyno'd knows that you can have a 10-15hp difference between even back-back dyno runs on the same car!!!!
Here is the results/performace of the exhaust shoot out that someone posted on the forum.
PEAK HP:
1. Borla 8.2
2. Stillen 8.1
3. Injen 7.6
4. Nismo 6.3
5. 5Zigen -3.4
PEAK Torque:
1. Stillen 7.3
2. Injen 5.1
3. Nismo 4.5
4. Borla 2.7
5. 5Zigen 0.2
wanderingstuden
Jan 28, 2016 07:03 PM
