installing helix high flow cats
Old Sep 27, 2005 | 11:05 AM
zbanshee's Avatar
zbanshee
Default installing helix high flow cats
i want to order them but installing them...im going to give them to a shop, will they know wat to do in terms of welding? and wat exactly must be welding? im very confused
Old Sep 27, 2005 | 11:53 AM
ZinMiami's Avatar
ZinMiami
No welding involved in a typical installation. It all bolts together at the stock locations.
The welding I had done was custom work to have a metal tab put on each cat to allow them to bolt to the OEM support bracket. Normally the Helix cats don't have this ability. I just chose to do it for my own peace of mind. To my knowledge everyone on here that uses Helix does not do this nor have they mentioned the need.
Old Sep 27, 2005 | 11:59 AM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
No welding needed on mine. The shop, however, may need to slightly modify your floorpan in order for these to fit properly so that it won't rub or vibrate.
Old Sep 27, 2005 | 12:16 PM
zbanshee's Avatar
zbanshee
so you think the shop will figure everything out?
Old Sep 27, 2005 | 12:24 PM
silverstone04's Avatar
silverstone04
modify floorpan = hit it hard with the biggest hammer available
I would hate to see that done to my car
Old Sep 27, 2005 | 12:35 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
If they are a competent shop, they should now exactly what to do.
It's not as bad as you make it sound. They just had to hit it a tiny bit, so it won't rub against anything. Wasn't much at all. As mentioned, they MAY do this if needed.
Old Sep 27, 2005 | 06:21 PM
ZinMiami's Avatar
ZinMiami
Not really a big deal. Just reshaping the metal a little bit. Can't even see it.
Old Sep 27, 2005 | 06:25 PM
nine49kid's Avatar
nine49kid
installing these should be pretty self explanatory
Old Oct 17, 2005 | 09:00 AM
screener's Avatar
screener
So do you have to pound the floor pan to make the Helix pipes fit properly? I thought it was on the G35 that needed this done.I'm looking to invest in high flow cats but would rather spend the extra so they fit without mods to floor pan.So should I just get the Crawford ones?Also has anyone exprierenced any issues without the oem support brackets not being on the Helix?(cracked,broken welds etc.)
Thanks
Eric
AbrasiveRaysive
Sep 20, 2021 02:29 PM
