Borla TD or new y pipe??? long...
Old Oct 10, 2005 | 01:46 PM
Beeker's Avatar
Beeker
Default Borla TD or new y pipe??? long...
So far I have installed a popcharger and Strup headers. I just ordered Motordyne's new 5/16 thermal spacer kit. I am going to install that and a grounding kit after I dyno my car. I just installed the headers last week. I did a baseline before I installed them so I can see how much of a difference just the headers made.
Anyway, after I install the spacer and grounding kit the next thing I plan on changing is the exhaust. I may go FI, probably a supercharger, one day but that won't be for a long time, if ever.
While I was installing the headers I realized the stock Y-pipe appears to be the weakest link in the stock exhaust system. I know the cats are restrictive but I don't plan on changing them. I don't like what I've read about test pipes and hi flow cats increasing rasp and noise levels. I don't want an exhaust that has obnoxious rasp or is too loud. Its getting border line too loud now with just the popcharger and the headers installed. From what I've read it's going to get even louder once I install the spacer. What I've noticed though is all the noise is coming from the engine bay. I can barely hear the exhaust. I think a slight increase in exhaust noise will help to balance everything out.
That brings me to my questions. Am I better off just buying a new y-pipe and keeping the rest of the exhaust stock or should I change the entire exhaust? Will a more efficient Y-pipe increase the exhaust note? I know the Borla TD will give better gains than changing the y-pipe only but will the difference be that noticeable between the two?
If I do change the entire exhaust I am leaning towards the Borla TD. It appears to be a bit louder than stock but keeps the sound deep with no rasp or drone. At least, from what I've read it does. It also is fairly inexpensive compared to other systems. I've been quoted less than $800.00 shipped. It also appears to give some of the best gains for an exhaust system. If you think I am better off changing the y-pipe only what brand do you recommend? I've seen the Megan for extremely cheap but I've heard their quality is horrible.
Sorry this post is so long but I wanted to give as much info as possible so people don't just say do a search. I've read just about every post about y-pipes and exhaust systems but I'm still not sure what to do.
Old Oct 15, 2005 | 09:07 AM
Beeker's Avatar
Beeker
Anyone?
Should I change just the y-pipe or the whole exhaust?
Old Oct 15, 2005 | 10:27 AM
ANXIOUZ's Avatar
ANXIOUZ
I don't know how a different Y-pipe will change the sound given your setup but I say just get the Borla. It'll give you some deeper sounds from the rear of the car to even things out.
Old Oct 15, 2005 | 08:56 PM
Acree's Avatar
Acree
they y-pipe will definately change the sound of the exhaust based on the size of piping and bends used, but the borla would be the best option as far as performance is concerned.
Old Oct 15, 2005 | 10:31 PM
Mike Wazowski's Avatar
Mike Wazowski
I loved the Borla while I had it, but I would suggest one thing if you go with it. Have it welded as the clamps that come with the kit are garbage and it will only be a matter of time before they start to leak. I cut out the resonators and welded the whole unit and it was great.
Old Oct 15, 2005 | 10:46 PM
hendo6682's Avatar
hendo6682
i would say get the borla td. i love mine. i gives a nice deep tone, no rasp and not too loud. i installed it myself and havent had any problems with any leaks or anything. good luck
Old Oct 15, 2005 | 11:03 PM
No need to search for the answer, or ask for recommendations, just look at member’s modifications.
sales@czp
Sep 23, 2019 03:30 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
codek
Sep 28, 2015 03:03 AM
