TurboXS UTEC goes Naturally Aspirated!
Old Oct 10, 2005 | 03:08 PM
BlackTuner's Avatar
BlackTuner
Talking TurboXS UTEC goes Naturally Aspirated!
2004 350Z
Blue Line Mods - TurboXS Intake & Test Pipes
Green Line (or yellow) Mods - TurboXS Intake, Test Pipes & Tuned UTEC
Light Blue Mods - TurboXS Intake, Test Pipes, APS Tall Boy Plenum & Tuned UTEC
Any questions???
Thanks,
Jermaine~
P.S. APS Plenum is Top Notch
I may play with a little race gas next
Old Oct 10, 2005 | 03:48 PM
booger's Avatar
booger
Great to see it working well . Do you have a A/F chart ? And does the Utec have a target A/F feature ?
Old Oct 10, 2005 | 04:10 PM
DomZ's Avatar
DomZ
When is the release date on this? TurboXS has nothing about it on their website
Old Oct 10, 2005 | 04:33 PM
BlackTuner's Avatar
BlackTuner
We do not use the dynopack Wideband we find that it's sample rate is too slow to tune a car properly. Our Tuner Product plugs into the UTEC and read AFR Data in each Datalog.
Thanks,
Jermaine~
Exact Release Date is TBA but I am shooting for this month definitely.
Old Oct 10, 2005 | 05:06 PM
Z350Lover's Avatar
Z350Lover
NIIICE... this is gonna benefit a lot of N/A tunings!!!! Good on ya!
cheers,
richie
Old Oct 10, 2005 | 07:06 PM
plumpzz's Avatar
plumpzz
man N/A is looking more and more tempting lol. the new ITB is supposed to be released soon.. i heard 30-45hp increase in power.. w/ 25-30 being more reasonable.. thast insane. add in cams and its even beter! we'll be seing 350hp 350s soon ? w/ more trq to butt.
Old Oct 10, 2005 | 07:11 PM
ThetunerFestNJ's Avatar
ThetunerFestNJ
Ahh...I see you made good use of that Plenum MRC Motorsports sent you..Nice job!
Old Oct 10, 2005 | 08:49 PM
BlackTuner's Avatar
BlackTuner
Yes, I did... I wonder did they enjoy the strippers I sent?
Old Oct 10, 2005 | 08:57 PM
ThetunerFestNJ
Yes they did, just nextime send FEMALE ones...
Old Oct 11, 2005 | 03:15 AM
mchapman's Avatar
mchapman
Is this the same UTEC module as used for FI cars?
Old Oct 11, 2005 | 04:35 AM
skyl1ne6mt's Avatar
skyl1ne6mt
Can some please clarify me on what are the differences between the UTEC and UNICHIP? Which one is better for NA cars? Thanks
Old Oct 11, 2005 | 06:02 AM
BlackTuner's Avatar
BlackTuner
This is the same unit used for Forced Induction.
The UTEC and the UNICHIP are two different units. Actually in the earlier days of the WRX market we used UNICHIP's. Once we began to tune more high power cars we would see that the UNICHIP lacked consistency. We would make multiple dyno runs getting everything right then it would knock because we didn't have exact Ignition Timing and it would forced the ECU to switch fuel maps. All the power made before was now lost because the car runs richer and has a total advance of less timing. The factory's ECU Timing Maps are very dynamic applying an offset to a roaming number is not ideal. We also ran into conditions where it's MAF Pull down function wouldn't equate to the same voltage between each new UNICHIP Module. -5% out of the fuel map on one box wouldn't give you the same AFR as another box, so before each box left our shop they had to be tested and calibrated on our bench. It was a complete nightmare.
This is essentially what created the brainchild called the UTEC. We wanted the ability to have a Plug and Play Engine Management Solution. The feature list included user tuning, actual ignition timing control, fuel control, datalogging, launch control, active knock correction, multiple map selecting, OBD compliancy and more. The UTEC allows us to have multiple back to back runs which remain consistent.
Thanks,
Old Oct 11, 2005 | 06:21 AM
southern_info's Avatar
southern_info
How does this UTEC vs against lets say having your ECU Re-Flash or even a SAFC-II?
Old Oct 11, 2005 | 08:53 AM
Methane's Avatar
Methane
Will this UTEC piggyback be able to increase stock rev limit and speed limiter?
Old Oct 11, 2005 | 09:06 AM
ThetunerFestNJ
I believe it will have the software to do so..Jermaine will be able to answer in more details.
Old Oct 11, 2005 | 10:04 AM
skyl1ne6mt's Avatar
skyl1ne6mt
so basically UTEC is far better than UNICHIP? I thought that UNICHIP works the same as UTEC, since it is also a piggyback.
Old Oct 11, 2005 | 11:12 AM
BlackTuner's Avatar
BlackTuner
To compare feature for feature the UTEC vs. Unichip would not be a fair comparison in my eyes. I like to refer to the UTEC as a Parallel EMS not a Piggyback.
Thanks,
Jermaine
Old Oct 11, 2005 | 11:20 AM
chemicalviper's Avatar
chemicalviper
Is this an NA application only or available for both or later boost option ?
And is this the first NA application TurboXS has entered into?
Old Oct 11, 2005 | 11:51 AM
BlackTuner's Avatar
BlackTuner
Our Engine Management Solution will work for both N/A and FI. So if you are planning to go FI, you can purchase the UTEC and cover both sides. TurboXS has N/A cars we playing with as well like the Lotus Elise
Thanks,
Jermaine~
P.S. The UTEC will have Rev Limit control in future software updates.
Old Oct 11, 2005 | 12:42 PM
xswl0931's Avatar
xswl0931
Does this mean a launch control feature?
