Make your own CAI!
Old Dec 29, 2002 | 12:04 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Default Make your own CAI!
I was searching websites with AEM info, and came across this one:
http://www.teamdelsol.com/howto/coldair/diycoldair.htm
It looks very interesting, and I think it will be a pretty nice weekend project for our Z. Anyone up to it?
Old Dec 29, 2002 | 07:18 AM
ares's Avatar
ares
Veteran
well, you might be able to, but you would obviously have to addapt it for the Z. also Im not sure steels is a good idea, as it can rust. now stainless steel is better, but still, it can rust.
that harder problems would be the bend coming out from the intake manifold, not quite 180. then you bend down, that is a 90bend, but then the red hose does a little S bend thing. dont know how you would mimic that..
Old Dec 29, 2002 | 08:22 AM
Moroccan_Mole's Avatar
Moroccan_Mole
howard, if youre upto it ... ill give you a hand.
but lets try on your car first ^^
Old Dec 29, 2002 | 11:45 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
Woke up this morning, did some measurement of stock intake pipe, but decided not to do the project now... I think the stock airbox has MUCH better design then I thought. I will keep my K&N for awhile..
Old Dec 29, 2002 | 11:52 AM
ares's Avatar
ares
Veteran
Originally posted by Craig01
I would'nt worry about rust, but the metal getting hot and putting hot air instead of cold air. You can build one out of black pvc piping that looks pretty good. Here's a link
http://www.densecharger.com/specs.htm
I know it's for mustangs but if you call John DeMolet he might be able to make one for the 350z.
one problem with the PVC piping is that youll get a no sound out of it, all insulated, the gutteral sound of an intake comes from the metal tube.
Old Dec 29, 2002 | 12:14 PM
2003z's Avatar
2003z
I've read that pvc breaks down at high temps and gives of harmful gasses. Not sure if its an old wive's tale though.
Old Dec 29, 2002 | 12:37 PM
ares's Avatar
ares
Veteran
if it is true, it might also require higher temps than youd find in an engine bay. but again, Im not sure either. havent ever heard that, but then again, havent used of pvc piping being used for anything hot. I think even hot water goes through copper piping in my house.
Old Dec 30, 2002 | 01:46 PM
N74DV's Avatar
N74DV
hmmm copper intake tubes anyone.... hahahaha
Old Dec 30, 2002 | 03:01 PM
zogan's Avatar
zogan
why do you think it is better?
Old Dec 30, 2002 | 03:52 PM
n3985's Avatar
n3985
Under no circumstance use PVC, it'll break apart in high temp. Instead, the BEST material to use is aluminum, light, and the worst heat conductor, even better, wrap it with thermal material = true cold air.
Old Dec 30, 2002 | 04:14 PM
N74DV's Avatar
N74DV
one of these days some of the CAI development companies will get smart and start using extruded aluminum piping with twin walls... sorta like those insulated house windows. two layers of aluminum combined with a small air chamber would insulate the intake air VERY nicely! just might get actual OAT coming into the engine.
Old Dec 30, 2002 | 04:47 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I think it's been covered, but here are two main things..
1. It has duct/opening to the front of the car, away from engine and most heat sources.
2. It is made of abs plastic, which doesn't absorb heats like metal type of piping..
Old Dec 30, 2002 | 05:03 PM
2003z's Avatar
2003z
Hey, lets not use too much aviation-think here!
Old Dec 30, 2002 | 09:56 PM
Red350Z's Avatar
Red350Z
haha--"OAT"--I was thinking exactly the same!!
Old Dec 30, 2002 | 10:22 PM
N74DV's Avatar
N74DV
yeah.... my brain eats, drinks, sleeps aviation...
seriously though... a 10 degree drop in intake temp makes a difference... a double walled intake tube could effectively take another 10 degrees or more off the intake temp.
sales@czp
Sep 23, 2019 03:30 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
Tochigi_236
Sep 27, 2015 03:40 PM
