Installed Greddy Evo2, now it rattles...help!?
Old Nov 14, 2005 | 11:38 AM
rico3682's Avatar
rico3682
Default Installed Greddy Evo2, now it rattles...help!?
Hey, I just had my Greddy Evo2 Catback installed. Looks and sounds amazing, but I get a rattle from the mid to rear passenger side, especially when I hit bumps in the road. I remember reading about this in someones post, but I cant seem to find it again. Anyone know how to cure this? Thanks in advance.
-Eric
Old Nov 14, 2005 | 12:51 PM
jhp1025's Avatar
jhp1025
I just had the same issue with my EVO2 when I installed the Crawford Cats. The fix is to loosen al of the bolts from the Cats back and lift the exhaust into place. Make sure you have plentl of clearance from the mid chassis brace and the sway bar. Then tighten the bolts from the front to the back. If this does not get rid of your problem, then you may have to put some washers between the mid chassis brace and the frame to drop the brace down a little bit.
Hope this helps. Good luck
Old Nov 14, 2005 | 04:39 PM
rico3682's Avatar
rico3682
Thanks. Im going to go back to the shop and see what they can do. Ill let them know about using washers to space the brace a bit. i think its hitting something else tho, im not sure. anyone else? is this common with the greddy evo2?
Old Nov 15, 2005 | 11:46 AM
sisco534's Avatar
sisco534
Make sure it clears, some shops will turn you lose not looking
Old Feb 20, 2006 | 07:19 AM
rico3682's Avatar
rico3682
anyone else? still havent gotten this taken care of.
Old Feb 20, 2006 | 08:04 AM
drumma022's Avatar
drumma022
I had to install some washers to act as spacers on the stock cross brace to stop it from rattlilng when I installed mine.
Old Feb 20, 2006 | 11:52 AM
rico3682's Avatar
rico3682
good call, im going to try that. where in fla are you located?
Old Feb 20, 2006 | 11:58 AM
roncfpz's Avatar
roncfpz
Try to find the location and/or tight spots and use some header wrap. Most shops with some experience installing this system will usually know the trouble spots.
sales@czp
Sep 23, 2019 03:30 PM
