I recieved the new MREV mod in the mail!!
Old Nov 24, 2005 | 07:43 AM
  #41
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Sorry if its too technical.
Also being a rocket propulsion engineer/scientist at Boeing, it is the normal expectation that all claims are described in technical detail. Performance claims aren't (can't) be accepted at face value. They must be proven by sound analysis or test data. The propulsion test reports and critical design reviews I present to NASA, JPL, PhD's, program managers and executives often require much more intense technical detail.
What I write for the Motordyne product descriptions may be a bit more than required but its a good practice to maintain.
Tony
Old Nov 24, 2005 | 08:18 AM
  #42
rolling's Avatar
rolling
i understand that except in most cases, that it just generates more questions, confusion to not all, but Most people on here like this thread as an example!
BTW where do you find time to write on here with all else you have going??? hehhe
thanx for info!
Old Nov 24, 2005 | 08:44 AM
  #43
Hydrazine's Avatar
Hydrazine
thanx for info!
LOL I ask that myself sometimes. I work extra hard to make the time. I'll transition full time to MD soon anyways. I'll need the time to develop other new projects currently in the works.
Old Nov 24, 2005 | 09:56 PM
  #44
STRETCH's Avatar
STRETCH
I read all the posts and I still have a question...Maybe I just missed the answer, but If I have an '03 287 with the '05 300 lower plenum, what option would be ideal? Would a spacer make a difference? Thanks in advance
Old Nov 25, 2005 | 06:20 AM
  #45
Hydrazine's Avatar
Hydrazine
I suggest using the 287 collector with a plenum spacer. Your new peak HP will be similar, if not a little higher and the peak will occur at about 6K RPM rather than at redline.
You will also have extra TQ and HP everywhere else on the curve.
It all looks like a win/win situation. If you try it, please post your impressions and get it pre/post dynod if you can. For you, its the equivalent of inatalling a MREV on a 287 engine but without the variable valve timing and 7000 RPM redline.
Old Nov 29, 2005 | 07:10 AM
  #46
partshipperdave's Avatar
partshipperdave
yep, using just the revup plenum will provide gains at the high end of the rpm band on a 287. Your best performance gains can be had by putting the 287 plenum back on, and get the 5/16" iso thermal spacer kit.
We have them ready to ship!
Stevo Z
Oct 3, 2015 09:14 PM
Dymsi
Sep 29, 2015 11:32 AM
Tochigi_236
Sep 27, 2015 03:40 PM
