pop charger
Old Dec 25, 2005 | 01:39 PM
rory's Avatar
rory
Default pop charger
i just got a jwt pop charger and i was wondering if anyone has ever tunned their z with a intake. i dont think ill be doing any other mods anytime soon.
thanks rory
Old Dec 25, 2005 | 07:33 PM
I believe that you are talking about programming the ECU? Sounds like an expensive proposition ($185-$385) for just one mod.
Old Dec 25, 2005 | 07:34 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I highly doubt anybody has done it. You would get as much gain from a Pop-charger and tuning as tuning a stock Z imo, like David said not very worthwhile.
Old Dec 26, 2005 | 10:30 AM
Never Mind's Avatar
Never Mind
so the JWT popcharger is plug and play?
Old Dec 26, 2005 | 11:41 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
Yes, the JWT intake or any other intake out there is bolt on and go. There is no ECU reflashing needed. You can actually do all your bolt ons without needed a ecu reflash, don't let anyone else tell you different. its just that even though you don't NEED it, you CAN benefit from one, with the more mods you do to get your Air/fuel and timing under control. I had everything including cams with my car before I even considered a reflash.
Technosquare did mine, and Andy's here, they do good work, but like i said, leave it to the last thing that you do, you don't need it really before then.
Old Dec 26, 2005 | 01:26 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Wrong. You contradict yourself by saying you don tneed one but you can benefit from one. For some of us doing all the bolt-ons makes us need a reflash to see the gains and get A/F safe. My car had over 15:1 A/F and was barely running faster than stock at the track because of the ECU retarding timing so it wouldnt detonate. In my case and others you do need a reflash afer all thhe bolt-ons. It doesnt matter what you had before you considered a reflash did you dyno test after every mod to check your A/F's? I did. You may have needed one before you did the cams. Your statement is just wrong, I could also say you can throw on a Greddy TT kit up the boost and not need to tune the car, but that wouldnt be very smart would it?
Old Dec 26, 2005 | 01:31 PM
Never Mind's Avatar
Never Mind
Thanks Tony, I appreciate it
edit: just saw Alberto's post..
say, if I only got the popcharger and the MREV spacer, do I need a reflash?
Old Dec 27, 2005 | 04:36 AM
Alberto's Avatar
Alberto
Cranky FI Owner
No prolly not. It takes more than that for you to need a reflash. If you do test-pipes combined with an exhaust those will lean you out, but even then your Z may still be within a safe A/F. Only one way to check, dyno it or get a wideband.
Old Dec 27, 2005 | 04:57 AM
Never Mind's Avatar
Never Mind
k' thanks
07ZEKE
Aug 23, 2021 09:15 PM
kyin
Oct 15, 2015 05:54 AM
_bit
Oct 2, 2015 07:49 AM
