Injen Install....Dyno Results
Old Mar 30, 2003 | 03:57 AM
  #41
silverstonez33's Avatar
silverstonez33
Default ...
I hear ECU learn rates vary, and in fact the VQ35's if very very fast. Thoughts?
Derek
Old Mar 30, 2003 | 03:20 PM
  #42
phile's Avatar
phile
Default Re: OT:350Z just like my old RSX-S
Originally posted by Mr Fairlady
if you are dynoing,..unplug your negitive Cable for like 20mins,..then plug it back in-you will see a HP gain,...it has to re-learn all the settings which is why some are seeing gians on the dyno,...untill it learns all the conditions it will feel better,..but after,..you probably won't see much till the ECU is "FLASHED"!
what do you mean unplug the "negative" cable ? DO you just mean unplug the ECU?
btw, I had a 2002 rsx-s too. I had it for 6 months, and traded it in for the Z. I did like the car alot though
Old Mar 30, 2003 | 05:05 PM
  #43
fdao's Avatar
fdao
Default Re: Re: OT:350Z just like my old RSX-S
I believe what he meant was to unplug the negative battery terminal cable.
Old Mar 30, 2003 | 05:35 PM
  #44
phile's Avatar
phile
Default Re: Re: Re: OT:350Z just like my old RSX-S
that's what threw me off though. You really can't just "unplug" a battery terminal...
Old Mar 30, 2003 | 08:38 PM
  #45
S12 driver's Avatar
S12 driver
Has anyone tried a o2 simulator? Maybe one from a Maxima or other VQ engines? If the ecu always sees the perfect a/f ratio, maybe it will not adapt and cut back power.
Old Mar 30, 2003 | 10:24 PM
  #46
fdao's Avatar
fdao
Default Re: Re: Re: Re: OT:350Z just like my old RSX-S
I guess the correct term should be "disconnect"
Old Mar 30, 2003 | 10:59 PM
  #47
zland's Avatar
zland
Sport Z Magazine
This ECU seems to be a pain in the ***! Cutting hp. what a joke!
lapham3
Oct 7, 2022 03:15 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Z King
Vendor Wanted
13
Oct 22, 2015 11:39 AM
