test pipes...smoke...now no oil!!! ahhhh
Old Dec 31, 2005 | 07:44 AM
cracka350z's Avatar
cracka350z
Default test pipes...smoke...now no oil!!! ahhhh
well i went through 5 quarts in less than 3000 miles....i know its not a head gasket...no smell except through the exhaust...any ideas?
Old Dec 31, 2005 | 08:22 AM
Sometimes we complete a mod, notice problems, and the problem has nothing to do with the mod. That seems to be what has happen here: oil consumption and test pipes are not related.
Bad valve seals
Worn valve guides
Pressurized crankcase (oil pan) due to a clogged breather system
Blow-by from worn piston rings
Its time to get the car to a mechanic.
Old Dec 31, 2005 | 08:47 AM
plumpzz's Avatar
plumpzz
U mite want to put stock stuff back on and take to stealership and ask for warranty.
Old Dec 31, 2005 | 03:22 PM
cracka350z's Avatar
cracka350z
you think they will give me a hard time about the test pipes? i know they have nothing to do with it....they cant lol...i flow the exhaust better....therefor i lose 5 qts of oil in less than 1000 miles!!! (thats how long ive had the test pipes)
Old Dec 31, 2005 | 03:24 PM
cracka350z's Avatar
cracka350z
i noticed when i came to a stop...my oil light came on and shut off really quick....came to the next light and was coming to a stop and watched my oil psi gauge drop to !ZERO! and my butthole puckered.....so i stopped and got some oil cuz it was bone dry!
Old Dec 31, 2005 | 04:41 PM
Zexy's Avatar
Zexy
Old Jan 1, 2006 | 08:18 AM
Zivman's Avatar
Zivman
replace the test pipes with your stock cats and take it to the dealership. I can pull test pipes off in about 15 minutes. It will save you a world of frustration.
Old Jan 2, 2006 | 06:29 AM
Axelerate's Avatar
Axelerate
I had the exact same problem.
Smoking and burning oil. The smoke is not as bad with the stock cats but still there.
Nissan replaced my entire motor under warranty. I had to deal pretty much direclty with NNA because the dealership was dragging their feet.
They will want to do a consumption test which takes quite a while to complete, I told them to worry about the smoking and fix that. Then while at the dealership the car started to leak oil and that sealed the deal and the next week I had a new motor.
Dont let them give you "We have never heard of anyone having this problem" crap. There have been a handfull of people on this sight with similar problems and I can gie you all me info if you want to use me as a reference for NNA.
Defeinetly put your stock cats back on. You dont want to give them any excuse.
Old Jan 2, 2006 | 09:03 AM
VeeTec's Avatar
VeeTec
Mine had a cracked crank pulley, which was causing the oil to leak out. It was replaced under warranty. My pressure did not dropped too low, but I noticed the smell of oil, which was very strong, and after a trip to the dealer, they located, and fixed the problem.
Old Jan 3, 2006 | 06:23 AM
cracka350z's Avatar
cracka350z
im not leaking...just burning...its gay!
apex locator
Jul 23, 2021 02:27 AM
issyz
Jul 2, 2017 03:04 PM
