JWT Install now CEL
Old Jan 9, 2006 | 03:26 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Default JWT Install now CEL
I just installed JWT a pop charger and now I'm have a CEL. Will this go away? Also how can/do I reset the ECU?
Old Jan 9, 2006 | 08:00 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well I'm going to run by Autozone tomorrow to have the code pulled. Still need to know how to reset the ECU please. I've already try disconnecting the battery.
Old Jan 9, 2006 | 08:19 PM
Dubai's Avatar
Dubai
http://www.technosquareinc.com/350reset.htm
Old Jan 9, 2006 | 09:31 PM
sokudo9l6's Avatar
sokudo9l6
how long did you disconnect the battery for? Try it again and leave it unplugged for like 10mins. Meanwhile, make sure everything(especially the MAF sensor) is plugged in correctly.
Old Jan 9, 2006 | 09:40 PM
When you installed the pop charger, the battery was disconnected correct?
Old Jan 9, 2006 | 11:16 PM
Roggan's Avatar
Roggan
Did you start the engine with the MAF not propperly connected? I did that once, had a CEL for a week or so (car ran flawlessly), then it went away by itself.
/Roger
Old Jan 10, 2006 | 05:03 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks guys. Going to get the code pulled today. I had the battery disconnected for about 5 mins at most.
Old Jan 10, 2006 | 05:09 AM
southern_info's Avatar
southern_info
Did you disconnect your MAF when installing your Popcharger? I've heard peeps do and some don't. I didn't when installing mines and I'm just intrigue as to could this be the reason. Maybe you got some type of debrie inside the connection. Try blowing air into the connection and reconnect it again with the battery disconnected. Then wait a couple minutes before connecting the battery.
Old Jan 10, 2006 | 05:11 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I did disconnected the MAF when installing it.
Old Jan 10, 2006 | 07:45 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Alright... Went and had the codes pulled. Got two of them: P0102 & P0113. Both are in relation to the MAF. I'll try to reset the ECU and see what happens. Worst case I'll wait it out and see if it doesn't reset itself.
Old Jan 10, 2006 | 08:12 AM
03track's Avatar
03track
so does this mean that you got the cel because you disconnected the maf? i left mine connected and did NOT get a cel.....but i also left my battery unplugged for a few hours.
Old Jan 10, 2006 | 08:14 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Don't know? To honestly find out you would need 2-Z's to install the Popcharger and one not disconnect the MAF and one to disconnect it to honestly find out.
Old Jan 10, 2006 | 09:22 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by scarface9
THANKS!!! That worked. No more SES light.
Old Jan 10, 2006 | 11:42 AM
Thumbs up
Old Jan 10, 2006 | 12:55 PM
plumpzz's Avatar
plumpzz
If u d/c the maf, itll cause u to get a CEL. and if ur going to rest the computer w/ the battery, leave it unplugged over night, or after u unplug it, hit the brake so u drain any power out of transitors.
Old Jan 10, 2006 | 05:49 PM
sokudo9l6's Avatar
sokudo9l6
i d/c the MAF sensor while i installed mine...left the battery connected too and no CEL.
sokudo9l6's Avatar
sokudo9l6
Old Jan 10, 2006 | 05:50 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for the double post. LOL
