Whistle Noise After Header Install
Old Jan 10, 2006 | 11:56 AM
qmaster's Avatar
qmaster
Default Whistle Noise After Header Install
I recently got the Strup headers installed on my '04 Coupe. Now for some reason, whenever I shut the engine off after driving, after about 10 seconds of silence, I hear a loud whiny whistle noise coming from under the hood. It starts out quiet and then gets louder, staying on for about 10 seconds.
I opened the hood and it seems to be coming from somwhere deep in the engine bay.
Could it be some kind of exhaust leak, as there are no odd smells, no CEL, and no other problems of any kind since the install?
Thanks.
Jason
Old Jan 10, 2006 | 11:59 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
the best solution is to bring back to the place where you have your header installed, they can check all the gasket/leakage for you.
Old Jan 10, 2006 | 12:29 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
well, you do have more air moving through the exhaust system now, but should hear a whistle...
sounds like they have the crank case blow by hose that goes into the bottom of your intake tube crimped / bent so its not wide open...
Old Jan 10, 2006 | 12:42 PM
plumpzz's Avatar
plumpzz
Jasons right. I had that on my car when i installed my intake manifold. Its pretty common and its not bad. If you shut ur car off in a garage w/ ur hood open it sounds like a loud WHOOOSH that gets louder as it stops. I figured its the vacuum in the engine filling w/ air :-D Who knew?
Obadabot
Jun 18, 2023 11:31 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
