OMG !!!! Look at this crap!!!
Old Jan 25, 2006 | 08:40 PM
DayBlueZ's Avatar
DayBlueZ
Default OMG !!!! Look at this crap!!!
I have noticed i have been getting louder for a week or two, so i finally got time to look under the vehicle.
I put on Test Pipes from Tuningpros.com (Megan, pretty sure) and all hell has broke loose.
My Gruppe Y-Pipe is cracked, my B-Pipe is cracked and the test pipes are cracked.
You think the test pipes could have caused all this?
This sucks bad!
Attached Thumbnails OMG !!!! Look at this crap!!!-gruppe-1.jpg   OMG !!!! Look at this crap!!!-gruppe.jpg   OMG !!!! Look at this crap!!!-stock-b1.jpg   OMG !!!! Look at this crap!!!-stock-b.jpg   OMG !!!! Look at this crap!!!-test1.jpg
Old Jan 25, 2006 | 08:45 PM
g35pm's Avatar
g35pm
My gruppe-s y-pipe cracked, probably from me dragging my low *** car over speed bumps and driveways(damn long wheelbase).
Old Jan 25, 2006 | 08:46 PM
anotheraznguy's Avatar
anotheraznguy
did you have a flex pipe on the y pipe?
Old Jan 25, 2006 | 08:47 PM
DayBlueZ's Avatar
DayBlueZ
Yea, the Gruppe-S has flex on each side.
Old Jan 25, 2006 | 11:34 PM
DayBlueZ's Avatar
DayBlueZ
I just took the whole thing off. Y-pipe, B-pipe and tests. There is something rattling inside the Test pipes. In between the mesh and the cover. That was a BIG annoyance!!! That incessant rattling. The B-pipe is almost cracked all the way around. The Y-pipe is cracked just a tiny bit. The driver side test pipe has almost come all the way apart.
Old Jan 26, 2006 | 12:16 AM
FairladyZX's Avatar
FairladyZX
Damn, I hope the TP didn't cause all that...I got the same TP pipes on for a month now so far is no problems.
Old Jan 26, 2006 | 12:18 AM
Do the test pipes use or delete the OEM hangers?
Old Jan 26, 2006 | 03:27 AM
SpeedRcr's Avatar
SpeedRcr
did u take the brace out when you installed your test pipes?
Old Jan 26, 2006 | 03:29 AM
atadlo's Avatar
atadlo
the megan's do not use the OEM converter bracket
Old Jan 26, 2006 | 03:36 AM
froggy's Avatar
froggy
Probably what happened for DayBlueZ + resonance to finish it
Old Jan 26, 2006 | 07:38 AM
DayBlueZ's Avatar
DayBlueZ
Yup, they have no hanger bracket.
My car isn't lowered. I don't drag. So it's not that.
Old Jan 26, 2006 | 07:43 AM
mgl's Avatar
mgl
i had the same ypipe and it cracked in the same exact place. i ended up getting a name brand ypipe (JIC) and have not had any issues.
but in your situation that is a lot of cracks.... maybe the combo of your engine brace and the quality of megan and the gruppe-s stuff has something to do with it?
Old Jan 26, 2006 | 08:27 AM
DayBlueZ's Avatar
DayBlueZ
I don't know. It beats anything i've seen.
I think it has to do with having no bracket mounts.
Old Jan 26, 2006 | 10:50 AM
vfr350's Avatar
vfr350
My Gruppe-s y-pipe cracked same spot after one season, stock cats. Guess you get what you pay for....
Old Jan 26, 2006 | 11:29 AM
deviant1's Avatar
deviant1
Add another cracked Gruppe-S y-pipe
Had mine installed for about 8 months before I noticed it was cracked. For the first 7 months, I had JUST the y-pipe installed. It wasn't until after installing a set of Helix Cats (without the cat bracket installed) that this happened.
I'm back to the stock y-pipe now, but I can hear more exhaust leaks under the car again I'm about ready to give up on exhaust stuff for this damn car.
Old Jan 26, 2006 | 11:34 AM
Thanks. I doubt that it matters. Test pipes are light. The probability of test pipes stressing the entire exhaust system is slim.
Old Jan 26, 2006 | 11:35 AM
mgl's Avatar
mgl
i don't think you should give up, just buy higher quality parts.
Old Jan 26, 2006 | 11:57 AM
DayBlueZ's Avatar
DayBlueZ
I agree, buy a better product. I will never buy anything from Gruppe-S again.
Old Jan 26, 2006 | 12:44 PM
FairladyZX's Avatar
FairladyZX
Have the muffler shop wield the crack for around 20 bucks.
Old Jan 26, 2006 | 12:59 PM
Rickdogg's Avatar
Rickdogg
Out of hiatus
Wow! That is terrible. It looks like you need to upgrade to a better y-pipe. My JIC has held up really well considering I track the SOB
