Motordyne 5/16" spacer = loss of power??
Old Mar 2, 2006 | 07:47 PM
  #62
fairladyZ in Japan's Avatar
fairladyZ in Japan
Originally Posted by mc350z
i also dont have any marks of contact on the plenum CAI or strut so it might not be touching. if it is all i need to do is add the washers i left out
I had to use the extra washers. (Luckily, the OEM bolts and the MD bolts were the same size as I have a somewhat early Z - Jan 2003 build.)
Old Mar 2, 2006 | 08:04 PM
  #63
bacalhau16's Avatar
bacalhau16
i can go to the dyno and use it for 1 hour for $50, i was trying to get to get an appointment with him to use it for a little while longer, as i install all my stuff!
i dont think that thats too much money, because by no means am i rich!
Old Mar 2, 2006 | 09:05 PM
  #64
ROGUELITE's Avatar
ROGUELITE
the Zbler eLf
yeah the reason i asked about others clearence compared to mine is everyknow and then i hear a metal "klanging" sound im not sure if its the plenum touching the strut or even something back around the spare tire. sound travels funny in this car so im not sure if its from the front or back.
just from looking at my pics a few posts up does that seem to be about what you guys clearence looks like?
had the same problem. the strut was clearing the plenum at rest but on throttle you could hear some klanging. double-checked the clearance and saw there was a small scratch from where the strut was rubbing the plenum on throttle. had to readjust the strut for additional clearance and all was well. the important thing is to make sure if clears enough to account for throttle.
Old Mar 4, 2006 | 08:37 AM
  #65
350ZUL8RZ's Avatar
350ZUL8RZ
When I put my car on the dyn the first time, I had a blue hydroshield on my Injen CAI. I pulled:
247.84 RWHP & 234.54 torque.
On the second and third pull I took off the Hydroshield and pulled:
250.14 RWHP & 237.30 torque
250.17 RWHP & 237.91 torque
I thought that the Hydroshield was not restrictive, but the proof is in the pudding.
Old Mar 4, 2006 | 09:51 PM
  #66
fairladyZ in Japan
My strut bar has about 1/4 inch minimum and 3/8 inch maximum clearance over the plenum.
I headed out early Sunday/March 5th on a 230 mile run on the expressway and mountain twisties. No problems (except RPMing the hell out of the engine) !!
Old Mar 4, 2006 | 10:20 PM
  #68
fairladyZ in Japan
thanks for the pics. from the 2nd pic it looks like you got a little more room than me. how does the car feel down low? any noticeable loss or does it feel good through out?
I still "feel" some low torque loss .. but a VTEC-type of feeling as the RPMs spool up from 3,500 ......
I am still planning on unhooking the negative battery cable for 24 hours .. and see what happens with any ECU reset. Just haven't had the time ---
Old Mar 5, 2006 | 04:33 AM
  #69
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I notice the same when I installed mine w/ PopCharger and Pulley. I added the APS race pipes about a month later and that brought back my low-end power and "smoothed" the power out. Only thing I could think of is that I was getting all this air in but couldn't get it out. Now I need a tune.
Old Mar 5, 2006 | 05:21 AM
  #70
fairladyZ in Japan
Interesting. Thanks for the feedback.
Also, what kind of "tune" are you planning to do ?
Old Mar 5, 2006 | 05:28 AM
  #71
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Your welcome. I plan on using the TurboXS UTEC for my tuning needs. My tuner & myself feel that with the UTEC & my current set-up we should get about another 15whp & 10-15wtq. If you haven't done research on it I highly suggest you do.
Old Mar 5, 2006 | 08:42 AM
  #72
rolling's Avatar
rolling
what engine do you have again?
and would you buy the kit if you could do it over?
was it worth it?
Old Mar 5, 2006 | 08:47 AM
  #73
Robert_K's Avatar
Robert_K
Didn't Go Cheap
You had those dyno numbers with just a CAI??? What type of dyno and they have to be SAE corrected.
Old Mar 5, 2006 | 06:42 PM
  #74
350ZUL8RZ's Avatar
350ZUL8RZ
I am sorry you were missled to believe that all I have is a CAI.
I actually have the Injen CAI, Motordyne 5/16" plenum spacer & Greddy Evo 2 cat back exhaust...
Old Mar 5, 2006 | 09:53 PM
  #76
Robert_K's Avatar
Robert_K
Didn't Go Cheap
And you dynoed 250 & 237? Nice numbers. Refresh my memory but you don't have a baseline correct? The reason I'm asking is cause I dynoed 249 & 236, mods in sig, gaining 17hp & 10tq. I don't know if our power is coming from the spacer or one of our dyno's is reading low or high?
Old Mar 6, 2006 | 02:57 AM
  #77
fairladyZ in Japan
I've got the JDM NISMO ECU.
Old Mar 6, 2006 | 03:02 AM
  #78
fairladyZ in Japan
was it worth it?
I've got the 287 engine .. and yes, I would do it again .. especially with the plenum cooling (gaskets and coolant valve control). Definitely worth it.
I recommend you do it .. very inexpensive mod - and most people have raved about it.
