Cleaning the JWT Pop Charger
Old Feb 21, 2006 | 01:16 PM
Z Rider's Avatar
Z Rider
Default Cleaning the JWT Pop Charger
Ok guys....I have had the Pop charger for a while and have been very pleased with the performance. Only problem is that its almost black in color now! ( i guess thats what you get for living in a city ). Basically, I really need to clean this thing...only problem is that i have no experience cleaning oil filters. Im guessing there is proper procedure for doing this. Any advice on how to do this correctly? Thanks in advance.....
BTW. My newly acqurired Nismo Exhaust is MIND BLOWING!!!! Cant get enough of that sound......
Old Feb 21, 2006 | 01:27 PM
See: https://my350z.com/forum/search.php?searchid=987933
Old Feb 21, 2006 | 01:34 PM
amacahilig's Avatar
amacahilig
here click on this.
http://www.jimwolftechnology.com/wol...ANING-INST.PDF
Old Feb 21, 2006 | 09:52 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
My little explination...
You do not have to remove the whole Pop-Charger from the MAF Housing. There is a large clamp that holds the filter element on the velocity ring. Loosen this clamp and remove the filter. Rinse the filter from the Inside-Out (have water flow out of the filter in the oposite direction in which the air travels into the filter). Rinse until the water runs clear. Let the filter element dry for 30-40 Minutes (sitting over crumpled up newspaper helps speed the drying process). Once the filter is dry, apply oil to the out side of the filter (do NOT over oil). Let the filter dry for another 45 minutes. If any white spots appear apply another spray of oil and let dry. Once the filter is dry and no oil is dripping, re-install the filter and tighten the clamp.
Old Feb 21, 2006 | 09:57 PM
JisNis's Avatar
JisNis
Ur supposed to spray the cleaner on the filter first. Inside out, then run the water.
Old Feb 22, 2006 | 12:14 AM
InZpire's Avatar
InZpire
Default Popcharger sounds different ...
What he said, just make sure it's really dry.
Old Feb 22, 2006 | 11:43 AM
PoWeRtRiP's Avatar
PoWeRtRiP
what cleaner are you talking about?
Old Feb 22, 2006 | 11:46 AM
JisNis's Avatar
JisNis
I used K&N cleaner instead. It somes with a cleaner. The oil makes ur JWT turn red though.
Old Feb 22, 2006 | 11:48 AM
PoWeRtRiP's Avatar
PoWeRtRiP
oh haha, i thought for a second there you put the oil on first then washed it out. i was hoping that wasnt the case.
kyin
Oct 15, 2015 05:54 AM
_bit
Oct 2, 2015 07:49 AM
