Installed my Labree test pipes finally!! Question??
Old Feb 28, 2006 | 04:52 PM
Tortuga's Avatar
Tortuga
Default Installed my Labree test pipes finally!! Question??
I installed my Labrees finally. Install went well. I used new gaskets and checked for exhaust leaks....none found. Everyone's advice on using long extensions to get at nuts from top of engine and using jointed socket extensions is appreciated, made it much easier.
I really love the exhaust note, just sings. Popcharger, MD spacer, Labrees and Borla TD together is so sweet. Not too loud either unless I'm at WOT...then it'll bark at ya. LOL.
My questions is: Since no CEL came on, does this mean that my emissions are still fine? Has anyone had there car inspected with the Labree TP on? I am in Texas and the new inspection procedure is to connect a computer to the OBD II interface and check for codes. Something like that I think. Just had my inspection in December so if I have to swap OEM cats back on, no problem. Just curious. Thanks in advance.
Old Feb 28, 2006 | 05:17 PM
InsaneChink's Avatar
InsaneChink
im glad you like your Labree's, damn i sure do miss mine. But as for the smog... the reason you CEL is not flashing is because you have an '03 or '04. But that does NOT mean you will pass smog. You know all the gas you are smelling now?? Well, you're smog tech will be able to smell it too.
Old Feb 28, 2006 | 06:43 PM
ct350z's Avatar
ct350z
i just recently installed my lebree's too. i freaking love them. i just need to get an exhaust system now, looking to get the hks hi power.
Old Feb 28, 2006 | 07:23 PM
bacalhau16's Avatar
bacalhau16
if your check engine light is not on, then you should pass. If your techs do it like they do here in massachusetts, they hook it up to the obd II adapter, run their program, and if all checks out ur good to go. It doesnt have to go on the exhaust machine thing unless your light is on.
in fact my friends turbo integra, passed for his sticker and he has no cat either.
Old Feb 28, 2006 | 07:32 PM
MR.OKKKK's Avatar
MR.OKKKK
my SES didnt come out.. then 2 days later.. BAM it came on... T.T now i gotta do the non fouler trick...
Old Feb 28, 2006 | 07:39 PM
bacalhau16's Avatar
bacalhau16
the non-fouler trick will absolutly work as stupid as it is. Its funny how some $5 parts from autozone does the trick that some $100 complicated electronic devices attempt to do.
Old Feb 28, 2006 | 07:48 PM
This question is best in a regional forum but...
Depends on the test. You will fail a sniffer test. For a OBDII read out, if the is no history of emissions codes, you should be fine.
Old Mar 1, 2006 | 03:22 AM
SpeedRcr's Avatar
SpeedRcr
tortuga...just go to a non emmisions county and get it inspected there...12.50 for the safety inspection and the sticker is the same
Old Mar 1, 2006 | 10:09 AM
Tortuga's Avatar
Tortuga
SpeedRcr - I heard that you have to get the inspection done in the same county you reside in. I am not sure if true or not. I guess next December I'll try to find out. I may just go and try and if it fails I'll just swap the cats back on and retest.
Tylerx7z33
Sep 21, 2015 01:43 PM
_koubie_
Sep 20, 2015 06:34 PM
