plenum spacer w/stock exhaust
Old Mar 1, 2006 | 06:22 AM
amacahilig's Avatar
amacahilig
Question plenum spacer w/stock exhaust
sup, a quick question.... is it work getting a plenum spacer while having a stock exhaust? if installed will i see/feel the maximum gains of the spacer? i know that more air in--> needs more air out. but what do you guys think? thanks
Old Mar 1, 2006 | 06:27 AM
blasian's Avatar
blasian
I'm sure most people would agree but the stock exhaust system isn't all that restrictive so I don't see why you wouldn't see gains. I don't have a plenum spacer yet but it is next on my mod list
Old Mar 1, 2006 | 06:55 AM
titanjc's Avatar
titanjc
I previously had a Kinetix V4 plenum with the stock exhaust, and noticed big gains high in the RPM range (over 4500rpm). So yes, the spacer will be worth it with the stock exhaust.
Old Mar 1, 2006 | 07:13 AM
amacahilig's Avatar
amacahilig
will the Motordyne 5/16" Plenum Spacer fit under the stock strut brace?
Old Mar 1, 2006 | 07:18 AM
The results will be similar regardless of other mods.
Old Mar 1, 2006 | 07:20 AM
For complete details about all spacers see the Motordyne site.
Old Mar 1, 2006 | 09:51 AM
ML2000's Avatar
ML2000
amacahilig the 5/16 spacer will fit under the stock strut brace. Also if you have an 06 you will have to get the MREV kit, hope this helps.
Old Mar 1, 2006 | 10:26 AM
Beeker's Avatar
Beeker
It does fit under the strut bar but a few of us unlucky people have had problems with the hood slightly bulging. All cars are slightly different so you may or may not have a problem.
If I lower the STB so the hood doesn't bulge the intake manifold will rub STB every once and awhile. When I raise it so it doesn't rub the manifold the hood bulges slightly.
When I say "bulges" what I mean is the hood sits slightly higher than the quarter panels. It's not that big of deal but when you look at the car from the side you can see that the hood is higher. It wouldn't bother most people but when you have O.C.D. like me it does!
Old Mar 1, 2006 | 10:37 AM
amacahilig's Avatar
amacahilig
heh O.C.D. monster got you too! thanks for the info. i have an '03, so i guess i won't need the MREV kit. a huge help everyone
Old Mar 2, 2006 | 06:20 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I have the 5/16th spacer with other supporting mods and stock exhaust w/ APS cat-deletes and love it. Read sig!
Old Mar 10, 2006 | 05:09 PM
Combat350z's Avatar
Combat350z
So I have to get the one with Mrev even though I have an 06 5at?
Old Mar 10, 2006 | 05:17 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
No. The MREV is for the REVUP motor. The AT's have the 287 motor.
So what you need is a plenum spacer. 5/16" is the most common option because you can keep your stock strut bar in place.
Old Mar 11, 2006 | 09:21 AM
Combat350z's Avatar
Combat350z
Ahh thanks. Now if only I'd have chosen the 6spd.
Old Mar 11, 2006 | 10:34 AM
eddie3782's Avatar
eddie3782
O.K. so if I have an 05 track I got to get the MREV, whats the difference with the MREV and the normal 5/16 spacer?
Old Mar 11, 2006 | 12:16 PM
Hydrazine's Avatar
Hydrazine
A spacer alone doesn't do anything for a revup engine. A revup engine must have the MREV to make a real change.
And it works very well.
Old Mar 13, 2006 | 10:58 AM
Goofy1477's Avatar
Goofy1477
I just got the AAM Spacer and intake. Sounds really good and I feel a small gain on the "Butt Dyno" lol Besides that, I am all stock, but the 3.9 final drive and the JWT clutch and flywheel
Old Mar 13, 2006 | 11:22 AM
99atlantic's Avatar
99atlantic
Why do people always write 'i'm all stock, except for flywheel and gears and this and that'. It's almost as bad as people who think having a twin turbo w/ 30lbs of boost is lightly modified
Old Mar 13, 2006 | 01:53 PM
Goofy1477's Avatar
Goofy1477
Because I have no other bolt ons, such as the exhaust, cats etc.
Old Mar 13, 2006 | 03:17 PM
mdracer76's Avatar
mdracer76
LMAO! @ Goofy and 99atlantic
Old Mar 13, 2006 | 03:52 PM
99atlantic's Avatar
99atlantic
stock is stock.
not, 'oh well, i have a twin turbo and cams and gears and nitrous and exhaust, so i'm lightly modified'
sales@czp
Sep 23, 2019 03:30 PM
Li1ag
Sep 28, 2015 02:07 PM
