Help with plenum spacer
Old Mar 5, 2006 | 08:34 AM
jmr0311's Avatar
jmr0311
Default Help with plenum spacer
I need some help guys. I'm trying to install the Motordyne plenum spacer but I need help with this. What is this "Teflon Putty" that the instructions calls to have. Is these some kind of paste tube, Can it be called differently. Thanks guys for your prompt response cause I'm in the middle of this.
Old Mar 5, 2006 | 09:10 AM
iyah's Avatar
iyah
I can't help, but send me pics!! =P
Old Mar 5, 2006 | 09:34 AM
99atlantic's Avatar
99atlantic
WTF are you talking about? there's no need for any putty in an MD 5/16'' spacer install.
Old Mar 5, 2006 | 09:42 AM
yellz's Avatar
yellz
Are you putting a gas line together?:
Old Mar 5, 2006 | 09:55 AM
plumpzz's Avatar
plumpzz
I dont think ur gonna need putty. When i put my plenum mod on, i just used a gasket. Gasket sealants like teflon sealants would make a mess and probably gum up ur intake valves if you put too much on..
A simple gasket should be enough.
Old Mar 5, 2006 | 10:01 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Go to your local parts dealership and pick up a 2nd gasket.
Old Mar 5, 2006 | 10:11 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The teflon pipe thread putty is supposed to provide a seal at the coolant control valve (CCV) threads.
You essentially put a thin layer of the pipe thread putty on the brass barbed hose fitting threads and screw the fitting into the CCV. This will provide a leak proof seal.
You can find the teflon putty at a hardware store. The reason to use the "Teflon" variant of pipe thread putty is because it is designed to handle high water temperatures.
And the putty only goes on the two 1/8 NPT threads.
Old Mar 5, 2006 | 11:50 AM
onebadfyvo's Avatar
onebadfyvo
I appreciate the clarification, Tony. I just got mine waiting at my doorstep on Friday. Will be installed in a couple of days. I can't wait!!
Old Mar 5, 2006 | 11:56 AM
jmr0311's Avatar
jmr0311
Thank you Tony (aka Hydrazine) for your professional reply. This was the kind of help I was looking for because I'm not very mechanic oriented. And to the other people that replied, peace guys, I'm just a newbie trying to learn.
Old Mar 7, 2006 | 12:05 PM
team1320350z's Avatar
team1320350z
anyone know what spacer gives you beter horsepower, AAM or Skunk2?
Old Mar 7, 2006 | 01:18 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Refer to my sig. I highly suggest the Motordyne 5/16" Spacer.
Old Mar 7, 2006 | 01:39 PM
team1320350z
i removed my skunk2 spacer and found a little bit of oil around it, is it normal? Anyone else had something like this?
Old Mar 7, 2006 | 06:35 PM
FairLadeeeZ's Avatar
FairLadeeeZ
I installed my 5/16 spacer last week.. Used the teflon putty around the CCV as well.. Install took a lot longer than i thought.. My fault though, really should have read the instructions very carefully. I was almost done twice, but then had to take apart again because 1) forgot to put the gasket and 2)had to take off the 4mm screws.. All in all.. great mod and definitely feels faster! Still have to put my strut on though, car is driving like shhht
Old Mar 7, 2006 | 06:55 PM
You reviewed the Sport Z magazine plenum vs plenum shoot out correct?
Old Mar 8, 2006 | 07:32 AM
Jay'Z's Avatar
Jay'Z
id like to see this shootout..... can u put a link up.. thanks......
allmycarsdie
May 13, 2016 04:38 PM
AbrasiveRaysive
Sep 13, 2015 09:52 PM
