What The Eff?
alrite, heres what it is. so im at the gas station last night and i saa a buddy of mine who also has a Z. were talking and what-not, and i mention the plenum spacer i have on mine. so naturally he wants to see and hear it, so i pop the hood and notice two little marks on top of the plenum. i look up at the under side of the hoodand see tha same marks. its rubbing! im driving w/out the strut bar for now because its on backorder. WTF! suggestions?
Something doesn't sound right if your plenum is rubbing on the hood!!!! What brand and size spacer are you using??? It is rubbing at the front or back of the plenum?
I have the AAM 1/2" tapered spacer and have the strut bar in with spacers to lift it up. The strut bar slightly rubs on the hood but that means that the front of the plenum is a least an inch below the hood.
I've heard of strut bars rubbing the hood a bit, but never the plenum itself. This must make one hell of a racket under acceleration (with the engine moving/torqueing about).
Originally Posted by 350Zylow
i have the 5/8 spacer and it rubs in the middle of the plenum on both sides
and it makes no noise, i think it only hits when the engine is torqued
PM Hydrazine on this board, he's the guy behind Motordyne and should be able to help you out with a solution to this.
I have a 3/9ths in. plenum spacer from Motordyne and I am running 1/2 in. hood spacer that are basically big washers that screw onto your bolts for your hood and raise the back up. A lot of people don't like the look but it's a pretty widely used mod. Also increases air flow into the engine bay and better cooling as a side effect. Talk to hydrazine and he can probably tell you where you can buy them.
I have a 3/8ths in. plenum spacer from Motordyne and I am running 1/2 in. hood spacer that are basically big washers that screw onto your bolts for your hood and raise the back up. A lot of people don't like the look but it's a pretty widely used mod. Also increases air flow into the engine bay and better cooling as a side effect. Talk to hydrazine and he can probably tell you where you can buy them.
