Catalytic Converter "Bracket"
Old Mar 7, 2006 | 07:54 PM
dskang100's Avatar
dskang100
Default Catalytic Converter "Bracket"
When you take off the catalytic converters for the car there is a sort of "\__/" shaped piece that has to come off before we take the cats off. If my memory serves me correct that's the general shape.
Now my question is.. What happens if this piece isn't connected? When I got my cats removed, then stock cats put back on the people didn't attach that piece again.. Was just curious. Thanks!
Old Mar 7, 2006 | 08:20 PM
MR.OKKKK's Avatar
MR.OKKKK
i believe thats the ones to hold the stock cat. converter... dont really need it with aftermarket testpipes or HFC
Old Mar 7, 2006 | 08:23 PM
Z BOY's Avatar
Z BOY
it helps support the weight so you don't stress the joints.
Old Mar 7, 2006 | 08:45 PM
MR.OKKKK's Avatar
MR.OKKKK
yea now im starting to worry... should i go back and get it installed?
Old Mar 7, 2006 | 08:47 PM
Z BOY's Avatar
Z BOY
if you have a jack, its easy to diy.
edit: just saw you have tpipes. nm.
Old Mar 7, 2006 | 09:05 PM
dskang100's Avatar
dskang100
Actually mine is not connected, and i've had my stock cats back on for awhile. Now when I go around i hear a shudder probably from the cats moving around. When it gets warm i'll do it at home i guess :-)
Thanks.
Old Mar 8, 2006 | 09:15 AM
pln2311's Avatar
pln2311
I left mine off when I put on the HFC's. No problems.
Old Mar 8, 2006 | 04:31 PM
ZinMiami's Avatar
ZinMiami
I think the statement "not needed for aftermarket cats" may need to be scrapped.
https://my350z.com/forum/intake-exhaust/167339-omg-look-at-this-crap.html
Old Mar 8, 2006 | 05:33 PM
The brace that you are talking about goes across the center and attaches to the black support. If you have that bracket, and it fits, sure put it back.
Old Mar 8, 2006 | 05:41 PM
Z BOY's Avatar
Z BOY
https://my350z.com/forum/showthread.php?t=167339
ya, i cracked a set of hf cats once. i def think all a/m cats/pipes should have a place to attach the crossbar.
Old Mar 10, 2006 | 12:54 PM
Zquicksilver's Avatar
Zquicksilver
+1
There is a reason the Nissan engineers placed a flex-brace in that exact location. It allows the exhaust system to flex, but eliminates a majority of the hanging weight between the engine block and B-pipe hanger. My Helix HFCs did not come with this brace, so I rigged something up for myself the day I installed them. I've inspected the welds and joints and everything looks fine a Year later. This spring I'm going inspect the joints and welds again and replace the rubber connection on my "HFCs bracket" with a solid bar. I feel the rubber bushings on the U-brace do their job and the rubber piece on my brackets is just overkill. The addition of this rigid piece will strengthen the overall system that much more. I'm definitely doing this before the Nismo exhaust goes on in a month or so.
I bought the U-bolt with rubber connector and perforated bar at Pep Boys...
GL,
Zquicksilver
Old Mar 10, 2006 | 01:09 PM
godmans's Avatar
godmans
Originally Posted by Zquicksilver
+1
GL,
Zquicksilver
According to your solution, you will have to add ALOT of braces, which I don't think is cost effective...
Old Mar 10, 2006 | 01:23 PM
Zquicksilver
I think you may be confused by the illustration...
The "red" represents the welds undergoing stress do to the lack of 2 brackets or braces attached to the stock U-brace. Just like the engineers intended... You can purchase the multi piece U-bolt brackets at PepBoys for $7... A $14 dollar solution
Zquicksilver
Old Mar 10, 2006 | 05:57 PM
Z BOY's Avatar
Z BOY
Zquicksilver
good idea, quicksilver.
sales@czp
Sep 23, 2019 03:30 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
350z_z33.
Sep 9, 2015 09:50 PM
NYGiants0186
Sep 8, 2015 10:37 AM
