Test pipes problem?
Old Mar 23, 2006 | 03:25 PM
Hawwwy's Avatar
Hawwwy
Default Test pipes problem?
I just intalled my test pipes on my Z and i drove off and everything was cool. The next day i started my car and drove down the block and the "service engine soon" light came on... How do i get it to go away? (I'm sure you guys have seen this post a million times, sorry!) Thanks!
Old Mar 23, 2006 | 03:43 PM
Mike Wazowski's Avatar
Mike Wazowski
non fowlers to fool it.
or get a code reader and just keep erasing the code.
Old Mar 23, 2006 | 03:54 PM
BamBam's Avatar
BamBam
I use the code reader every now and then to clear the persistent codes. But a lot of the time it clears itself up after a few days...
Old Mar 23, 2006 | 04:11 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
that normal. It will goes away later.
Bubble's Avatar
Bubble
-REPLICA ARMY-
where u buy it? and how much?
Old Mar 23, 2006 | 04:17 PM
Mike Wazowski
You can get one at any autozone/pepboys/kragen for less than $100.00. Actron(sp) is the ones I have. I have a base model that was like $50.00 that I keep in the wifes car and a Model with more functions that I got for $99.00 that I keep in my Z. Comes with the CD that has all the SES codes, but the reader itself spells out what is wrong and also give you the code.
Old Mar 23, 2006 | 04:23 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I have had my SES light on since I install my TP w/ nonfowlers. Had the code pull and it is the O2 senors. Any other suggestions?
Old Mar 23, 2006 | 11:14 PM
FairladyZX's Avatar
FairladyZX
Get two packs of HELP! Spark plug nonfoulers - part number 42002 or 42009 (either will work) - these are readily available at Autozone, Checker, Pep Boys, etc.
Drill ONLY 2 of the nonfoulers out with a 1/2" drill bit. Fit 1 NON-drilled fouler into each test pipe. Fit 1 drilled nonfouler into the previously installed undrilled fouler on each bank. Finally insert your o2 sensor into the drilled nonfouler and reconnect the wires.
Old Mar 23, 2006 | 11:17 PM
jmcmorante's Avatar
jmcmorante
WOW! I thought they would cost a lot more! Hmmm........something else to put on my B-day wish List!
Old Mar 25, 2006 | 07:00 PM
kevinapex's Avatar
kevinapex
I run Stillen race pipes, same thing with sel I got a o2 simulator that tricks the ecu. Cost like 25.00 It has worked for 1 year, on sel light.Do a Serch you will find it.
Old Mar 26, 2006 | 06:56 AM
A_16's Avatar
A_16
buy an 03 lol
nonfowlers for anything else basically
Old Mar 26, 2006 | 07:03 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I have an '03 w/ APS TP & Nonfowlers and still have the SES light.
Old Mar 26, 2006 | 09:38 AM
plumpzz's Avatar
plumpzz
if u have an 03, get rid of the non-fowlers.
Old Mar 26, 2006 | 09:39 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So the O3 shouldn't use the now fowlers?
Old Mar 26, 2006 | 12:53 PM
jinsei888's Avatar
jinsei888
correct
Old Mar 26, 2006 | 12:58 PM
Zexy's Avatar
Zexy
No need to since the SES light will most likely not turn on 03 models.
04+..Get the non foulers.
Old Mar 26, 2006 | 03:47 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well mine came on. LOL
Old Mar 28, 2006 | 11:15 AM
brnzbuddha's Avatar
brnzbuddha
I have an 03 with non foulers, and they CEL has come on as well. I got the code pulled its P0441: "The PCM has determined that the purge flow in the evaporative emission control system is incorrect for the current engine operating conditions." Any help?
Old Mar 28, 2006 | 02:18 PM
Hawwwy's Avatar
Hawwwy
Hey thanks guys! You guys all helped so much. I guess I'm gonna get the non fowlers and see what happens...
Old Mar 28, 2006 | 05:18 PM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Was tighting my belts today and notice my left O2 Senor harness wasn't plugged in all the way. Disconnected my battery for about an hour and now the SES is gone.
Uriyo_
Sep 8, 2021 08:46 AM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
