Power problems have risen for this 06'
Old Mar 30, 2006 | 07:30 AM
97supratt's Avatar
97supratt
Default Power problems have risen for this 06'
Hey guys, here are my mods and here is what happened.
K&N Filtercharger
Test pipes
Y-pipe
MREV
My car has been incredibly slow in the upper rpms (3500+) ever since I got all these mods. The MREV added some torque down low but i'm still losing power up top. I actually have tested my car against another 06 with only an injen intake and nismo exhaust and he keeps pulling. I'm wondering if the ecu is to blame. Any thoughts?
Arin
Old Mar 30, 2006 | 07:43 AM
dyezak's Avatar
dyezak
I may be wrong, but I think something has changed with the ECU in 06. The test pipes may be causing problems. This is a wild guess though. Try resetting the ECU and see if that helps short term...if it gets slower over time the ECU is compensating for something, my first guess would be the test pipes.
Old Mar 30, 2006 | 07:48 AM
97supratt's Avatar
97supratt
I've reset it a zillion times I think. I have done the negative battery terminal removal, I have done the manual reset by technosquare and none of them worked. I know its running very rich because my exhaust is black. I'm thinking its the test pipes also, but other people have such good luck with test pipes and now all of a sudden my engine loses power because of it. Anyone have any experience with the 06' ecu's that can chime in on this discussion?
Old Mar 30, 2006 | 08:54 AM
97supratt's Avatar
97supratt
Anyone?
Old Mar 30, 2006 | 09:17 AM
350Zteve's Avatar
350Zteve
One possible problem might be the K&N. If it came with too much oil, you may have gummed up the fine wires in the MAF. I've seen this happen before.
Old Mar 30, 2006 | 09:18 AM
Diesel350's Avatar
Diesel350
Several members have reported losses when adding test pipes. Don't know why. Try putting your stock cats back on and see what happens.
Old Mar 30, 2006 | 09:46 AM
97supratt's Avatar
97supratt
Funny thing is, the car got really slow after I installed the k&n.
Old Mar 30, 2006 | 09:49 AM
BlueBoxer's Avatar
BlueBoxer
Yeah, my K&N filter gummed up my MAF on my WRX and played havoc with me for a couple weeks until I finally figured it out. I had a loss of power and detonation because of it. I would switch back to your stock filter since that is an easy fix and see if it helps. Next, I would see if you can borrow your friends MAF to see it that fixes it. Again, easy test and switch. If that fails it will probably be your test pipes.
Old Mar 30, 2006 | 10:08 AM
jcarp's Avatar
jcarp
clean the maf and i wounder if you run a step colder plugs bc of it running rich if that would do anything.
Old Mar 30, 2006 | 10:12 AM
EM-EFER's Avatar
EM-EFER
It would make sense to run a hotter plug... more spark=more fuel burnt.
Old Mar 30, 2006 | 10:30 AM
97supratt's Avatar
97supratt
What are you supposed to clean electrical parts with, carb cleaner?
97supratt's Avatar
97supratt
Actually they say if you go colder you'll have a stronger spark.
Old Mar 30, 2006 | 11:40 AM
First you have to see if you are feeling a power loss or there is an actual power loss. So a dyno test is necessary for diagnostics.
What you may be experiencing is a lean fuel mixture at 3,500 plus. If so, its time for a ECU tune.
Old Mar 30, 2006 | 11:47 AM
Nismo 350z's Avatar
Nismo 350z
I think you over oiled your filter. Try replacing it and see if it helps. Also I would recommend a reflash. Usually once you do HFC's/TPs a reflash will help out.
Old Mar 30, 2006 | 11:54 AM
97supratt's Avatar
97supratt
I never oiled it. I opened the box and installed it, some people say you should leave it on a piece of newspaper overnight for it to dry off before installing (which I didnt do).
Old Mar 30, 2006 | 11:57 AM
Acree's Avatar
Acree
Or just buy a UTEC.
Old Mar 30, 2006 | 01:43 PM
Cannysage's Avatar
Cannysage
check for leaks. you should be able to hear something funny. I think it maybe your y pipe.
Old Mar 30, 2006 | 02:39 PM
97supratt's Avatar
97supratt
Actually I do have a leak in the y-pipe gasket but thats beside the point. I wouldnt lose that much power just from a exhaust leak.
Old Mar 30, 2006 | 04:16 PM
booger's Avatar
booger
Clean the MAF with some electrical cleaner , in a spray can .
Old Mar 31, 2006 | 12:39 AM
da45king's Avatar
da45king
I'm still trying to figure out....what mods do you have that are supposed to trump an injen cai and a nismo exhaust?? You have test pipes, and MREV (Which transfers some of the power from the top to midrange)....seems to me like a full exhaust is better than a Y pipe & test pipes.
I'm still trying to figure out how you are gonna win.
