MREV+ Dyno Tested On The 287 HP Engine!
Old May 27, 2006 | 11:13 PM
  #741
Zincognito's Avatar
Zincognito
finally installed mine yesterday! i have to say that it feels stronger or that it pulls harder. right after it, i installed Sun Hyperforce. and that made it feel smoother. so it pulls hard but smooth now........lol, i know
Old May 28, 2006 | 10:48 AM
  #742
GMZ's Avatar
GMZ
Yes I think I will be getting one of these soon!
Old May 30, 2006 | 04:33 AM
  #743
LMG_35C's Avatar
LMG_35C
Added MREV-2 to my 3/8" spacer on Sunday. Despite the earlier Dyno's indicating that the A/F leans-out, I think that it's made good power in the mid-range. 3rd and 4th pull harder than before. No baseline Dyno to compare but I'm happy with the change. Will be lining up some type of engine management so that I can put my HF Cats back and try getting this tuned.
Old May 30, 2006 | 05:32 AM
  #744
Jun's Avatar
Jun
what's the price f the MREV2 if we want to purchase it at this point? Do we still get a refund if we do a core exchange?
Old May 30, 2006 | 06:36 AM
  #745
dovla's Avatar
dovla
LMG_35C, do you notice any difference now above 5K RPM in sound or performance? Thanks
If I remember correctly, after ½” spacer was added to my car, there was an increase in sound above 3-4K RPM, and also huge performance increase. Now, with MREV-2 there is intake sound increase above 5K RPM but I don’t feel any performance change.
Old May 30, 2006 | 09:01 AM
  #746
LMG_35C's Avatar
LMG_35C
Very subjective...although the increase feels more noticable bewteen 3 & 5K, I think it does pull harder all the way to redline. Forgot to mention is that I also reset ECU - never tried that before ????
I was on the fence about this mod after seeing the dyno's but at this point I'll probably keep the MREV-2 and return my stock unit for the core refund.
Exhaust sound is a bit deeper - perhaps influencing my perception as well.
Now if I could only decide on what tuning route to go; simple APEXI for A/F, a reflash, or all out on a UTEC - wish they made this smaller & with better user interface.
Old May 30, 2006 | 03:39 PM
  #747
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
I installed my mrev2 about 2 weeks ago and I am going to have to say that it does pull harder in 3rd and 4th gear.. I haven't tried 5th and 6th gear pulls to redline, yet. I also go through 1st and 2nd gear a tad bit faster than I have before. There is also a slight increase in sound from the intake (I have a popcharger) but the exhaust note doesn't change enough to be noticeable.
Old May 30, 2006 | 04:56 PM
  #748
bosssho's Avatar
bosssho
Which car, G or Z, and which version of a tranny are you running?
Also, did you get the spacer too...or just the MREV V2?
Glad to hear you are happy.
Old May 30, 2006 | 05:09 PM
  #749
3hree5ive0ero
Retired Admin
I have a 2003 Daytona Blue 350Z Touring 6MT. I only have the MREV2 on my car, as I read earlier that having both the spacer and mrev2 would require a proper tune in order to get the maximum power gains. Without a tune, it doesn't gain much more from just the spacer nor just the mrev2 alone.
Old May 31, 2006 | 03:37 AM
  #750
nearly zer0's Avatar
nearly zer0
Sorry for not reading 37 pages of posts if this information is in there, but how would one obtain an mrev+ lower plenum? Website says it is sold out. Is there a group buy coming up?
Old May 31, 2006 | 04:41 AM
  #751
bosssho's Avatar
bosssho
Gotta love the older cars...still thinking they are the fastest! ;-) Yeah, w/both you should really get a tune to add fuel or else you will run lean/hot which will pull timing/power.
Nearlyzero, you will have to wait until the batch of core lower plenums comes back to ME b/f they have any real supply available...and fyi, it's only the MREV V2 that will be available now as far as I know.
Old May 31, 2006 | 08:21 AM
  #752
hvrod's Avatar
hvrod
Question
So will this work with my setup?
I have a crawford plenum,
Will all I need is an spacer , and the mod to the lower collector ?
Old May 31, 2006 | 06:44 PM
  #753
Jime's Avatar
Jime
Just to add a little flavor to the thread, this is what a Maxima looks like with a MREV-2 and 5/16" spacer added. Managed to pull a 12.9 @104 N/A automatic with slicks and a 13.2 @ 106 on streets.
Old May 31, 2006 | 07:28 PM
  #754
Zincognito's Avatar
Zincognito
I'm having the same questions about what tunning route. Im going FI in about 9 months and i dont know if spending the money on UTEC or a reflash is worth it until then. Thats why i was thinking of getting a simple apexi a/f to handle it but some say that it may not be safe. I dont have a spacer for the same reason that i will run lean but if an apexi can fix that then i will order the 5/16 isothermal kit. hmmmmm...........anyone have any answers to this?
Old May 31, 2006 | 07:39 PM
  #755
3hree5ive0ero
Retired Admin
You talkin to us 03 350Z owners? You wanna start something?
Old May 31, 2006 | 08:44 PM
  #756
abcdang's Avatar
abcdang
when you guys are installing the mrev2, why do you need to disconnect the negative terminal on the battery? the manual suggests that you do.
Old Jun 1, 2006 | 04:30 AM
  #757
LMG_35C's Avatar
LMG_35C
..easy insurance to prevent any electrical component damage, and necessary to avoid throttle body re-learning. It's much easier to disconnect the TB so that you can get the upper plenum completely out of the way. Remember to lower windows as well - you'll need to reset radio etc but my Homelink settings were't affected. I also reset the ECU while I was at it.
Old Jun 1, 2006 | 07:57 AM
  #758
3hree5ive0ero
Retired Admin
Old Jun 1, 2006 | 04:26 PM
  #759
brigz's Avatar
brigz
So i got in an Mrev2 in today, but my question is how can i tell its the mrev2 and not the mrev+? I can clearly see where it was grinded on the 1 and 2 intake runners but is it supposed tol look the same on 3 and 4?
Old Jun 2, 2006 | 02:28 AM
  #760
3hree5ive0ero
Retired Admin
From what I understand, mrev+ is basically just the 287 lower plenum with minor modifications.. mrev2 was machined, as you have noticed.. I'm not 100% sure as I've never researched to learn about the mrev+ (because I didn't need it).
