Worth swapping Nismo Y-Pipe for JIC Y-Pipe?
Old Apr 9, 2006 | 12:49 AM
gsazabi's Avatar
gsazabi
Default Worth swapping Nismo Y-Pipe for JIC Y-Pipe?
I currently have Nismo exhuast so obviously my current Y-pipe is Nismo.
Do you think it's worth swapping the Nismo Y-pipe for JIC Y-pipe?
I'm not sure how much it will help, but I might have to get one just
because I want to get Crawford Hi-flow Cats,
because I've found out that there's fitment issues with Nismo Y-pipe causing the Crawford Cats to crack.
But besides the Cats issue, is JIC that much better than Nismo?
I can tell that my Z's chocking and I need to free up a LOT of flow.
Current mods: JWT Pop Charger, 5/16 plenum spacer, Nismo Exhaust.
Any input/comment would be appreciated.
Old Apr 9, 2006 | 01:04 AM
Z BOY's Avatar
Z BOY
its not worth it, imo.
Old Apr 9, 2006 | 01:29 AM
Why would it be?
Old Apr 9, 2006 | 02:37 AM
gsazabi's Avatar
gsazabi
Only reason I was considering JIC was cuz of fitment issues...
How can I install Crawford cats with Nismo Y-pipe and not crack the
cats so soon? I heard v2.0 still has this problem.
Old Apr 9, 2006 | 02:45 AM
Z BOY's Avatar
Z BOY
fitment issues?
in my experience, if you run any cat without attaching it to that u-shaped crossbar, the cat is much more likely to crack.
Old Apr 9, 2006 | 05:55 AM
Lawn Dart's Avatar
Lawn Dart
I'm confused. The Crawford cats are known to crack and you are willing to dish out $450 extra in a gamble to replace a perfectly good part. Why don't you just spend an extra $500 on a better quality high flow cat? Hell, for a thousand dollars, you can almost buy the Nismo cats.
Old Apr 9, 2006 | 08:27 AM
gsazabi's Avatar
gsazabi
Yes they are known to crack, ESPECIALLY used with Nismo Y-Pipe.
There is a thread about it not matching right with the Nismo Y-Pipe,
and even the Owner of Crawford basically don't recommend Nismo with
their product.
Old Apr 9, 2006 | 08:32 AM
plumpzz's Avatar
plumpzz
u can try kinetix HFC? i havnt heard of those cracking w/ nismo Y pipe. You can probably sell ur nismo Y pipe and buy a used JIC.
Old Apr 9, 2006 | 11:15 AM
350Z_LMS's Avatar
350Z_LMS
Yes, there is a fitment issue but if you read a few threads on the subject, you will see the solution is there and it's quite simple (washers and spacers by the rear cross brace). Just make sure the cats you have are the more recent type (the "reinforced"). I asked Doug at Crawford and in my case yes, they are reinforced. Excellent customer service BTW.
Old Apr 9, 2006 | 11:24 AM
jcpeyton's Avatar
jcpeyton
I've got nisom exhaust w/ kinetix cats, installed w/o the oem brace. No fitment/cracking problems here.
Old Apr 10, 2006 | 11:50 AM
Zincognito's Avatar
Zincognito
i know this sounds ignorant but what do you guys think about JIC Y-pipe with Invidia Test Pipes on the stock exhaust? any cracking or other problems?
thanks
G
Old Apr 10, 2006 | 05:16 PM
jcpeyton's Avatar
jcpeyton
Does VA has emissions inspections? If so, you'll be removing the test pipes and re-installing stock cats every time you have to pass. Not that the removal/install is such a big deal-it's not-but just a factor to consider, especially if you don't do your own work.
There a more than a few hi-flo cats out there that pass visual as well as sniffer tests e.g. Kinetix, and thus don't require removal/reinstall every year or two. Also, they don't throw a CEL. Lots of test pipes do. So many products, so many options, so many prices. What are you trying to achieve? Maybe best to start w/ your goal in mind and buy parts consistent w/ that goal. Hope this helps a little.
Old Apr 10, 2006 | 05:19 PM
jcpeyton's Avatar
jcpeyton
BTY, if you have a nismo y-pipe you're looking to discard, I'll take it off your hands for any reasonable price.
Old Apr 10, 2006 | 05:57 PM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
In my opinion, hte JIC y-pipe is the best one out there today for the 350Z. It's design is as straight forward, and free flowing as you can get. Jeff here on his old orange Z actually swapped out his nismo y-pipe for a JIC and from what he says, he liked the power a bit better.
I doubt it's a HUGE difference, but i think that it would help especially to gain every last bit of power from the car. It's my favorite y-pipe on the market today for the Z/G35. I even had this on my old exhaust setup on my car, and would highly recomend it to anyone.
They are not too expensive (especially for the quality you get with it).
And we do have these in stock, (PM me if you would like pricing etc)...
Old Apr 11, 2006 | 07:53 AM
OCG35Coupe's Avatar
OCG35Coupe
It is my understanding that the Y Pipe outlets diameter should be smaller then the inlet of the exhaust. The JIC Y pipe has a 80MM Outlet, and the Nismo Exhaust has a 76MM Inlet.
I would recommend the Tanabe Y Pipe which looks as free flowing as the JIC and also has the flex joints. The Tanabe Y Pipe has a 70MM outlet, which would bolt up nicely to the 76MM Inlet of the Nismo exhaust.
Im most likely going that route, except with a Fujitsubo exhaust instead. (same 76mm exhaust)
Old Apr 12, 2006 | 12:15 AM
Zincognito's Avatar
Zincognito
Emissions wont be a problem because i have Texas tags therefore a different inspection decal . Getting inspection decals wont be a problem each year (dont ask) . Does the JIC throw a CEL and if they do how do you get rid of it??
Old Apr 12, 2006 | 12:19 AM
Zincognito's Avatar
Zincognito
Thanks for the help. i got offered JIC y pipe and invidia test pipes for a good price so i just wanted to make sure its what i want.
G
Old Apr 12, 2006 | 10:04 AM
Tony@Performance
No y-pipe will throw a CEL.
Old Apr 12, 2006 | 02:47 PM
Zincognito's Avatar
Zincognito
how would get rid of that?
ablaine
Nov 29, 2016 10:13 AM
nanotech
Oct 2, 2015 05:02 AM
