$200 bottle of LockTite
Old Apr 13, 2006 | 01:51 PM
Default $200 bottle of LockTite
About 5,000 miles ago I had headers installed. The mechanic mentioned Bring the car back in a week and I will torque all the bolts. I am a procrastinator, and did not return the car. Big mistake.
Sunday I was drag racing, and after the last run noticed how loud the exhaust was. A leak? Cracked catalytic converter? Bad gasket?
Today I took the car to the shop (different from the original). The header bolts had worked themselves loose, and the header - block seal was leaking. The shop had to remove and install the studs and bolts. This time with heat resistant LockTite. Cost: $200.
So to those installing headers. Buy a $10 bottle of LockTite and save yourself a big headache (and expense).
Old Apr 13, 2006 | 02:35 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
That sucks david. Good info though.
Is there a difference between heat resistant loctite and regular? I have seen various kinds at the hardware store (red, blue, etc) and I always get confused
Also, in the lab, we have a few screws that get up to 600 degC. We always use high temp anti-seize on these screws to prevent corrosion. Although these screws are not weight bearing like bolts for headers, and I'm not sure if it would be a good idea to use anti-seize on exhaust parts. So my question is, is loctite good for preventing corrosion due to high temp oxidation?
Old Apr 13, 2006 | 05:02 PM
I don't know. The work order says Heat Resistant LockTite - $10 so I don't know what it is. I just hope that it works. BTW the exhaust is much more quiet now that the leak is fixed.
Old Apr 13, 2006 | 05:08 PM
Quamen's Avatar
Quamen
I believe the reason behine the heat resistant part is that I think normal locktite will contract under heat and since it is hard will therefore crack. Kinda like mudd drying if you will. I believe the heat resistance either adds some flew to it or it just flat out keeps the molocules from contracting tighter therefore preventing it from cracking apart.
Old Apr 13, 2006 | 05:35 PM
Rhoads's Avatar
Rhoads
David you should have called Rob up and told him what happened. I bet he would have retorqued the bolts for free.
I hope mine dont work loose too. I had him check a few the other month and he said they were still tight...
Old Apr 13, 2006 | 05:36 PM
Rhoads's Avatar
Rhoads
Did you throw a CEL?
Old Apr 13, 2006 | 05:55 PM
I could have, but it was a matter of convenience. The car was in the shop here in Baltimore. A trip to and from PA would have been a day off work and a 4 hour drive. I am not at all upset with Pro Tune. As I mentioned in my OP, I should have had the install checked 4,000 miles ago.
Old Apr 13, 2006 | 05:57 PM
No. A header - block leak is before the first oxygen sensor, so no problem with emissions.
BEBO'S ZEE
Jun 7, 2016 07:48 AM
Twenty4
Jan 17, 2016 01:20 PM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
LunchBox20
Oct 20, 2015 10:22 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
