installed plenum spacer, now oil is leaking from the plenum gasket?
Old May 11, 2006 | 09:59 PM
nureulsaranghae's Avatar
nureulsaranghae
Default installed plenum spacer, now oil is leaking from the plenum gasket?
hi guys, I just installed motordyne 3/8" plenum spacer for my car, and when I got done installing the spacer, I have noticed a slight seepage of oil or oil like substance around the front side of the plenum gasket. is this unusual? the car seems to idle and drive fine. is there even supposed to be oil in this area? I am scared that I screwed something up during install causing this. The only thing I can think of is that I used the stock longer bolts for the front bolts with the spacer on. if the bolt was too long, and tightened too deep, could this screw anything up and cause the oil leak? or is that not possible?
any inputs would be very appreciated.
thanks guys in advance
John
Old May 11, 2006 | 10:21 PM
Z BOY's Avatar
Z BOY
why didn't you just use the bolts that came with the spacer?
Old May 11, 2006 | 10:37 PM
nureulsaranghae
If I use the wrong bolts is it possible to make the oil come up? Is that why u are asking me for not using the bolts supplied? I bought my spacer used and the guy said to use the stock long ones with short ones.
Old May 11, 2006 | 10:42 PM
Z BOY's Avatar
Z BOY
well, having installed a few spacers, i can tell you its not normal for you to be leaking oil as you describe, so yes, you're probably using the wrong bolts. also, be careful w/ the amnt of torque you use when tightening. you could strip the threads in your lower plenum if you use too much.
Old May 11, 2006 | 11:03 PM
I don't know how much oil you are talking about. There is some oily residue inside the plenum which you wipe with a towel. Its possible to get some of the oil on the gaskets. Then when you put the upper and lower plenum together, you might have some oily residue on the outside edge.
Motor oil simply does not come up.
Old May 12, 2006 | 06:16 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
Is your oil cap screwed in tight?
Chris
Old May 12, 2006 | 09:56 AM
first350's Avatar
first350
Chris
first time through, the little rubber seal around the oil cap got stuck between the upper/lower plenums...it had some oil residue from oil changes.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
