Upper and Lower Plenum Porting with Dyno
Originally Posted by StarcraftBW
those may be collapsed under extreme
Originally Posted by ZON
Wow you have an exceptional level of patience
Originally Posted by Quamen
Looks like it is coming along well. Good luck and hopefully you get some good gains.
Cool, very well done man....i am very positive with the result you will get.... keep us an update
Originally Posted by MurphysZ
What you see is the thinest part, it gets thicker as it goes back. Most of the runners are still over 1/2-3/4 inch think. It would be a potential problem for a turbo car but not N/A. The runners are still a lot thicker than any spot on the upper plenum.
That pic with the hack saw hanging there is classic.
Should go into the DIY Hall of Fame
great work though, this is how we all learn about our cars. Nissan may or maynot have tried this. Good luck with the dyno runs
looks get Murphy, about ur top plenum polishing (outside) what did u use to get it shinny? the flap wheel doesn't leave it exactly smooth and so far i've been smoothing it out my hand, which takes forever!
Here are pics from where I am with polishing now. The bracket holding the coolant line is one that I made. I am going to reroute the hose to get it off of the engine cover all together but here are some work in progress pics for you guys. I'm doing the engine cover on the car so the engine bay is dirty.
