Test Pipe Concern
Old May 30, 2006 | 02:06 PM
24v GTI Guy's Avatar
24v GTI Guy
Default Test Pipe Concern
I have a 2005 6sp Coupe. I'm about to purchase my exahust and i want to get LaBree testpipes however. I hate having a CEL on the dash. Thats the only things holding me back from testpipes. I had them on my last car and got used to seeing the light on my dash but if a real problem ever arrises, you'll never know because the CEL light is already on. Is there anyway to prevent the light other than the non fouler method which doesn't work on the 05+ ? Can it be tuned out by the dealer or software? Do any of the tuners do this?
Old May 30, 2006 | 02:31 PM
350Zteve's Avatar
350Zteve
Are you sure the non-foulers don't work on the 05+? I thought they did.
Old May 30, 2006 | 02:32 PM
Cannysage's Avatar
Cannysage
I did the non fouler on my 05 and it works like a charm.. who told you it didn't ?
Old May 30, 2006 | 02:37 PM
24v GTI Guy
How long have you had the Non foulers on your car? Alot of the info I was reading on the forums led me to beleive that the non fouler method works but only for a short period of time before the ecu eventually catches on. I remember reading some post where guys had test pipes for a maybe 2 months before the light came on which is good, but I'd prefer to have no light what so ever.
Old May 30, 2006 | 02:38 PM
Blurr350z's Avatar
Blurr350z
I think that it WILL work, and if not you can just have the code cleared. That way if another problem does arise, the light will go on again.
Old May 30, 2006 | 04:34 PM
24v GTI Guy
I'll give it a shot, hopefully it'll work out.
Old May 30, 2006 | 04:37 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I would say go for some high flow cats, avoid the troubles.
I have yet to put my kinetix cats on, but if they work, they will be great bang for the buck.
Old May 30, 2006 | 04:49 PM
Cannysage's Avatar
Cannysage
around 1k miles. I think you've been misinformed. with the previous to a 04 zs there's a chance it may not throw a cell at all (even without a non fouler). with 05 and up, it will throw a cell, no matter what. non fouler will work with all years.
Old May 30, 2006 | 05:16 PM
plumpzz's Avatar
plumpzz
nonfouler trick is not year dependant. It works on almost all cars.
Old May 30, 2006 | 07:21 PM
Agree. The non-fouler moves the post catalytic converter oxygen sensor out of the exhaust stream. When on-board emission controls compare the results of the two exhaust sensors, they appear similar. No problem.
Old May 31, 2006 | 01:13 AM
ISMSOLUTIONS's Avatar
ISMSOLUTIONS
Default Fast Intentions
Hey there - 2 things:
1 - Non foulers work fine and are the only way around the issue. Use HELP part number 42002 or 42009 at AutoZone. They will need to be drilled out to accommodate the O2 sensor head though.
2 - LaBree testpipes - if you want the quality, buy Fast Intentions. The lead engineers that made them to begin with left LaBree and opened their own shop months ago - Fast Intentions. LaBree does not have the talent there anymore - at all.
I just posted pix of the testpipes as well here
http://g35driver.com/forums/showthread.php?t=91857
If your familiar with specialtyz.com, the products used to be all LaBree, they are now all Fast Intentions. We have a group buy going on now as well in the vendor forum that includes the testpipes.
http://www.fastintentions.com
Rick
Old May 31, 2006 | 07:36 AM
ISMSOLUTIONS
Sorry - one more note: I have an 05 with headers and the testpipes - cams and head works and much more - no CEL with foulers - been running this way for over 7000 miles. I haven't heard of not working if it is done right. I do know of people who have over drilled the foulers though, so that could be an issue for some.
For $5 - you can't go wrong for trying...just make sure you reset the ECU.
Rick
Old May 31, 2006 | 02:09 PM
StarcraftBW's Avatar
StarcraftBW
So these don't make SES light come off?
Originally Posted by William@Altered
I also recommend the test pipes we sell here:
http://www.alteredatmosphere.com/mm5..._Code=350Z_EXH
Old May 31, 2006 | 02:14 PM
DG350Z's Avatar
DG350Z
I have APS TPs with non foulers (2005 Z) and I am continually throwing SES. I disconnected the negative terminal of my batt and the SES light went off for about 2 days then came back : \ Havent left the battery off for longer than a few minutes, so I may try leaving it over night. Dunno if it will make a difference though.
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
