Port Matching, Lower PLenum and Manifold!!
Old Jun 3, 2006 | 02:47 AM
aleok's Avatar
aleok
Default Port Matching, Lower PLenum and Manifold!!
alread port and polished the plenum, but how the hell do i take off the intake manifold? the fuel injectors are attached and idk how to take the things off. is there a DIY on the removal? thanks
Old Jun 3, 2006 | 04:13 AM
Julian@MRC's Avatar
Julian@MRC
Not to sound like a dick...But if you dont know how to remove the lower plenum, then you probably should get some experienced help..There is alot that could go bad doing that and not knowing how to do it properly..
Old Jun 3, 2006 | 12:14 PM
overZealous1's Avatar
overZealous1
simple, you just remove the bolts holding them on, lol.
Old Jun 3, 2006 | 12:41 PM
aleok's Avatar
aleok
i'm not talking about the lower plenum, i'm talking about the manifold that below the plenum. i'm afraid that if i just start removing bolts then i'll not know what i did or how to put it back.
plus i don't know what i should torque it back down too. anyone?
Old Jun 3, 2006 | 01:18 PM
ATL_Red_G35's Avatar
ATL_Red_G35
buahahaha, both sponsors are being owned.
He was talking about the Intake Manifold instead of the plenum set
Old Jun 3, 2006 | 01:31 PM
ATL_Red_G35
here you go, have fun. Post the results once you're done
Attached Thumbnails Port Matching, Lower PLenum and Manifold!!-1.jpg   Port Matching, Lower PLenum and Manifold!!-2.jpg
Old Jun 3, 2006 | 03:58 PM
aleok's Avatar
aleok
Ahh! thank you! where the hell did u find this??
Old Jun 3, 2006 | 04:39 PM
aleok's Avatar
aleok
actually could i explain to me what the "stud bolts" are? and does anyone know about the torque rates for the fuel injectors. (i got the thing off just fine, and only dropped 1 bolt (not into the cylinders) DAMN!!)
Old Jun 3, 2006 | 09:25 PM
failsafe306's Avatar
failsafe306
Torque the injectors to 50ft/lbs.
Old Jun 4, 2006 | 02:16 AM
aleok's Avatar
aleok
thank you. but that seems like a lot just the fuel injectors, since everything else isn't that much. plus the fuel injectors have those plastic thick washers that i would imagine it would be hard to get that amount of torque on them. ru sure its 50 FT/lb?? (sorry for doubting you..)
thanks
Old Jun 4, 2006 | 03:38 AM
100122923's Avatar
100122923
sub
Old Jun 4, 2006 | 06:35 AM
Julian@MRC's Avatar
Julian@MRC
50ft lbs???!!! the darn head studs only get 65ft lbs..You crazy man?
Old Jun 4, 2006 | 08:54 AM
failsafe306
lol
Old Jun 4, 2006 | 09:01 AM
failsafe306
aleok, I was just kidding man, sorry. I had alot to drink last night
If you're talking about the bolts that hold the fuel rails down, you want to get them between 15-20 ft/lb's.
Old Jun 4, 2006 | 10:31 AM
ATL_Red_G35
here's the full article.
Engine Mechanical
Old Jun 4, 2006 | 02:49 PM
aleok's Avatar
aleok
ha, ok thanks
hulkout
Tuning
Sep 30, 2015 12:33 PM
