Where to Place Wideband / EGT
hey guys, I did a search for this with no luck, so hopefully someone can help me out.
I'm looking to do either an AEM wideband and/or an EGT guage. With the V configuration, and 2 headers, I'm not really sure where I should be placing the sensors. I know the EGT should be as far upstream as possible in the header, but I'd really rather not do 2 (1 on each side).
So my question is WHICH SIDE? is there a 'hot' cylendar I should be looking out for? where have some of you guys placed the bung?
Thanks
Thanks
Thanks
Thanks
Later
Aceman
Originally Posted by aceman
I placed the bung on the driver side. I dont have cats, so i put it on my race pipes. Working great.
Later
Aceman
Later
Aceman
And that's for the Wideband right? not the EGT?
Yeah, thats where i but the Wideband.
EGT is for Exhaust Gas Temperature right? I would assume you could place it around the same area. I know the closer it is to the block the better. But how much of a temp difference would a foot make?
Later
Aceman
Later
Aceman
Later
Aceman
Anyway I was just curious, I know some cars will have one or two cylendars that run hotter.
Thanks
Thanks
i have a question, if u have hi flow cats, how far away does the wideband bung needs to be away from the o2 sensor. also, do u put it in front or back of the o2 sensor. this is for a supercharger application.
Originally Posted by 350Zteve
EGT is a waste IMO on anything other than turbo applications.
Thats how you blow a motor buddy.
This raises a good point. If the wide-band is only mounted on one side, than you can only monitor one bank of cylinders. What are the chances that one side could run lean and the other side will not? So should there not be a Wide-Band placed on each bank? Oh great...there goes another $400
-J
-J
350Z_Al
Oct 29, 2020 07:44 PM
