Test pipes and Check engine light?
Old Jul 2, 2006 | 02:51 PM
jtgli's Avatar
jtgli
Default Test pipes and Check engine light?
did a search and couldn't find anything. On the 06 model Z what do I do when I install test pipes on the Z. I know I'll get a cel but how do I eliminate it Software of wat?
Old Jul 2, 2006 | 03:04 PM
Use a non-fouler. The non-fouler moves the post catalytic converter sensor out of the exhaust stream.
Mike Wazowski's Avatar
Mike Wazowski
obviously you didnt search because over 100 threads came up about the subject.
https://my350z.com/forum/intake-exhaust/109158-want-to-get-rid-of-the-ses-light-from-removing-your-cats.html
Old Jul 2, 2006 | 03:13 PM
Demon Z's Avatar
Demon Z
I've been watching/reading on this subject for a while now. I just got a pair of test pipes (not installed yet) and had yet to read exactly what the non-fouler trick does. If I'm not mistaken, it is "sniffing" the air in between the two non-foulers that are to be installed. Is this more or less correct?
Old Jul 2, 2006 | 03:38 PM
Not exactly. You have two oxygen sensors:
One pre-catalytic converter sensor in the exhaust manifold (first photo).
And one post-catalytic converter sensor in the test pipe. The non-fouler goes in the test pipe essentially moving it out of the exhaust stream. So you trick the post-catalytic converter sensor by exposing it to clean exhaust.
Old Jul 2, 2006 | 03:45 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
LIAR!!!
There is an ECU reset trick using the gas pedal and ignition key. You'll need a stop watch to do it right.
Old Jul 5, 2006 | 09:02 PM
Black05Alti's Avatar
Black05Alti
Would the spark plug non fouler method work for the front o2 sensors? I have read to pu them on the rear. but why not on the front?
etkms
Jun 19, 2022 06:30 PM
JjL
East Canada
Jun 12, 2019 03:04 AM
350z_z33.
Jul 3, 2017 04:01 AM
_koubie_
Sep 20, 2015 06:34 PM
