Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)
Old Jul 12, 2006 | 05:13 AM
BocaCoupe's Avatar
BocaCoupe
Default Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)
EDIT: This is a REVUP
I decided to see if the MREV2 did indeed show an improvement over the MREV+ that I had installed.
The MREV2 arrived from Tony well packaged and I noticed additional machining over the MREV+.
I did have some aluminum dust from machining which I cleaned off using soap/water and drying immediately.
The swap was performed on the dyno per Tony's request and the engine temps were kept the same.
After doing the swap around 5 times, I had no trouble exchanging the lower plenum.
I did a total of 6 runs, 3 before, 3 after, with an ECU reset (pedal method) before the 1st 3, and the last 3.
I would like to mention that the run was done until the engine hit the rev-limiter so the last 500rpm or so drop off is really outside the normal operating RPMs.
In terms of the "Butt Dyno" I do see improvement around the midrange-topend.
It pulls to the top harder than before. I highly recommned this upgrade to anyone looking for more NA power.
P.S. Yes I know one of the plenum spacers was not installed when taking the picture.
Rob Dyno Video
Here are some of the Dyno's for you to check out:
Attached Thumbnails Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)-allsix.jpg   Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)-max261.jpg   Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)-max259.jpg   Revup MREV+ vs MREV2: Dynos Inside (both with 5/16th spacer)-261afr.jpg
Old Jul 12, 2006 | 05:54 AM
masterj26's Avatar
masterj26
is the g35 a revup engine as i see you rev to 7k
Old Jul 12, 2006 | 05:58 AM
BocaCoupe's Avatar
BocaCoupe
Yes, the engine went to revlimiter ~7400rpm
Old Jul 12, 2006 | 07:14 AM
ZLadie2000's Avatar
ZLadie2000
Did you need to adjust the A/F ratio??
Old Jul 13, 2006 | 06:37 AM
BocaCoupe's Avatar
BocaCoupe
Not sure about the A/F ratio, but the car pulls stronger now throughout the mid-top end.
Old Jul 13, 2006 | 06:54 AM
panapower's Avatar
panapower
I know that these engines love to run rich since we also tested some z's and G's and they all behaved the same. Rich as hell!
Old Jul 27, 2006 | 10:44 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Here you go!
Old Jul 27, 2006 | 11:10 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
thanks for posting the dynos for both mrev2 and mrev+
Old Sep 24, 2006 | 09:08 AM
Hydrazine's Avatar
Hydrazine
Bump for search question.
Old Sep 25, 2006 | 09:24 AM
Slick 6MT's Avatar
Slick 6MT
Thanks so much for performing the test, this was exactly what I have been looking for.
Hmmm ... now I need to figure out if it's worth the money to send in my MREV+ for 5 hp.
Old Sep 25, 2006 | 11:34 AM
Mazinger Z's Avatar
Mazinger Z
Awesome, did you have any other mods or just this ?
Old Sep 25, 2006 | 12:53 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I'd say go with something else... that's just me though...you've already spent the money on the plenum, now move on.
Old Sep 25, 2006 | 01:12 PM
kourosH's Avatar
kourosH
what else is on the car other than mrev2
Old Sep 25, 2006 | 02:46 PM
Slick 6MT's Avatar
Slick 6MT
Hydrazine told me that he'd machine my MREV Plus lower plenum for $122. Then I'd have MREV2 & 5 more horsepower.
So the question is if the 5 hp is worth $122.
Decisions, decisions ...
Old Sep 26, 2006 | 04:05 PM
Mazinger Z's Avatar
Mazinger Z
Yea do it...better deal than the popcharger
Old Sep 26, 2006 | 04:48 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
LOL is it worth the trouble to you? I guess that would be too much hassle for me, but we're not the same person.
Old Sep 26, 2006 | 07:27 PM
3hree5ive0ero
Retired Admin
Don't forget the shipping costs.
Old Sep 27, 2006 | 05:28 AM
Slick 6MT's Avatar
Slick 6MT
haha. That's what I was thinking!
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
