MREV2 with 5/16 spacer installed with Dyno on Rev-Up
Old Jul 14, 2006 | 07:00 AM
fini's Avatar
fini
Default MREV2 with 5/16 spacer installed with Dyno on Rev-Up
I finally got Mrev2 installed this week... and OMG... my car is so much more fun to drive! The sound is awsome.... and I can totally feel the gains when passing cars on the freeway. I'm the biggest skeptic ever, and I can tell you that this mod really works. Car drives so much better now!
I had Z Car Garage install Mrev2 on the dyno. He did 2 baseline pulls and 2 pulls after install. The dyno chart is the best of the 2 pulls. Very happy with the mod! I've been driving with Mrev2 for couple days now... and everytime i do... i go like this
Edit: I have an 05 G35 6MT. only other mods is stillen intake and ztube.
Old Jul 14, 2006 | 07:24 AM
mikead_99's Avatar
mikead_99
Congrats, I'm glad you like your results. I'm just curious what your other mods are. Your results are almost the inverse of mine, at least looking at your peak deltas. I gained very little hp, but a lot of torque, whereas you've gained a lot of hp and just a little peak tq. I do see that you did get some good tq gains acrossed the band, but still pretty different than my own results.
Old Jul 14, 2006 | 07:30 AM
mchong75's Avatar
mchong75
I wish I could install mine. Unfortunately, I am selling mine as of today. Brand new if anyone is interested.
Here's the link
https://my350z.com/forum/showthread.php?t=203600
Old Jul 14, 2006 | 07:37 AM
Brick-Z's Avatar
Brick-Z
Nice gains. I plan on purchasing the MREV and spacer pretty soon.....but wheels most come first
Old Jul 14, 2006 | 07:38 AM
fini's Avatar
fini
The only other mod I have is the Stillen intake and ztube. the reason for the little peak tq gain is because of the spike due to pinging (this is what the shop told me).
Old Jul 14, 2006 | 01:24 PM
dingobiatch's Avatar
dingobiatch
Is the 5/16 spacer going to do much ontop of the MREV2? I hear that on rev-ups, the spacer shows almost no gains.. but that might just be by itself..
Old Jul 14, 2006 | 01:34 PM
Armitage's Avatar
Armitage
Peak torque was never the big gain. It was the gain from like 3000-5000 RPM's.
Old Jul 14, 2006 | 01:36 PM
Brick-Z's Avatar
Brick-Z
Spacer on top of the MREV2 will produce very little gains. Optimal gains only come with the 287hp motor.
Old Jul 14, 2006 | 02:24 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
^That's not quite right.
The spacer does indeed make gains on the 287 motor with a 287 lower plenum.
But on a REVUP, the spacer by itself does not make gains if a stock REVUP lower plenum is used. But if you install the MREV2 on a REVUP engine, you want to also install the spacer.
On the REVUP engine, the MREV2 makes more TQ and the spacer makes more high RPM HP.
For the best results, use both on the REVUP engine.
Tony
Old Jul 14, 2006 | 02:27 PM
dingobiatch
Oooh. Gotcha.
Old Jul 14, 2006 | 03:26 PM
mikead_99's Avatar
mikead_99
Yeah I realize, thanks. I was refering to the peaks as a quick reference to the differences in our results, and actually more pointing out that he picked up more top end hp then I saw.
Old Jul 14, 2006 | 03:28 PM
97supratt's Avatar
97supratt
Hey Tony,
What if somebody uses a MREV2 + 1/2" spacer instead of 5/16"? Have you dynoed that combo?
Old Jul 14, 2006 | 07:40 PM
Hydrazine's Avatar
Hydrazine
Almost.
It was dynod with the first generation MREV. It make a little more peak power, but area under the curve was greater with the 5/16".
Old Jul 15, 2006 | 10:36 AM
masterj26's Avatar
masterj26
tony is there a dyno with the MREV2 and spacer on a 287, i thought i remembered reading the combo would only be beneficial with a tune
Old Jul 15, 2006 | 01:33 PM
blackznismo's Avatar
blackznismo
yeah i want to see results for MREV2 on a 287 motor...thanx
Old Jul 15, 2006 | 04:54 PM
Hydrazine's Avatar
Hydrazine
There were several huge threads running on this combo just a couple months ago.
Wired 24/7 did a comprehensive sequence of dynos showing the gains.
Nissan North America also tested it at their HQ in Torrance. It also showed great gains.
There has to be a hundred dyno plots of motordyne stuff all over this site. You just need to find them.
Old Jul 16, 2006 | 11:32 AM
m0rb!d's Avatar
m0rb!d
How much do mrev2's cost to install? Do I need to get a shop to do it (I don't know how to do anything on cars exept like install an intake and catback.)
Nice numbers, have fun with the new mod
Old Jul 16, 2006 | 04:33 PM
Hydrazine's Avatar
Hydrazine
You can do it yourself in about 1.5 hours.
Check out the instruction manual here:
http://motordyneengineering.com/manual.asp
to see if its something you can do.
Its pretty much all about turning 10mm bolts with a torque wrench.
Old Jul 16, 2006 | 08:06 PM
m0rb!d's Avatar
m0rb!d
aight thanks mans
