Exhaust Question
Old Aug 3, 2006 | 05:57 PM
MikeKondilis's Avatar
MikeKondilis
Default Exhaust Question
Have a question on my exhaust. I have a HKS Hi Power Exhaust and wondering what would go good on it some Helix High Flow Cats or some APS SS Test Pipes. Which one would sound good and not rice? And which ones dont mix with the HKS
Old Aug 4, 2006 | 02:25 AM
The answer is terribly subjective. High-flow catalytic converters will increase exhaust noise. Test pipes will increase noise a bit more.
Old Aug 4, 2006 | 06:27 AM
MikeKondilis
which one gives more WHP, or is more usefull
Old Aug 4, 2006 | 06:43 AM
mikead_99's Avatar
mikead_99
lol, tps will give more whp, but imo hfc's are more useful if you need to pass a sniffer emissions test.
Old Aug 4, 2006 | 07:46 AM
SBT's Avatar
SBT
ive heard it with regular test pipes and it doesn't sound as good
I think I've heard it with hfcs and it didn't change much
are you looking for sound, performance, or both? I might just leave it the way it is if you don't care that much
or get a set of resonated test pipes and pave the way for others with your setup on an NA car
Old Aug 4, 2006 | 08:17 AM
MikeKondilis
im going for both, but i want more sound but not rasp.. Want some performance gains also so I think im going to go with the test pipes.. Heard that APS Test Pipes are good... right? Will I be able to pass the emmisions also with test pipes
Old Aug 4, 2006 | 08:47 AM
singh's Avatar
singh
_______________
its required you have some kind of catalytic converter to pass....so no you wouldn't pass if you had CAT-DELETE Test pipes.
Old Aug 4, 2006 | 08:52 AM
VN_350z's Avatar
VN_350z
i'd recommend HFC over testpipes especially HFC with stock looks:
Pros:
1) extra hp
2) piece of mind w/ cop
3) smog check
4) no bad smell like testpipes
5) No ECU codes
Cons:
1) More money
2) Less HP than testpipes
Old Aug 4, 2006 | 08:57 AM
Good question for the regional forum. Test pipes and a OBD check – yes. Test pipes and a stiffer test – no.
Old Aug 4, 2006 | 10:03 AM
MikeKondilis
I guess im goinig to go with the Kinetix High Flow Cats then thanks guys
Justin100
Nov 29, 2015 03:58 PM
nanotech
Oct 2, 2015 05:02 AM
Li1ag
Sep 28, 2015 02:07 PM
