Motordyne 5/16 Spacer Question?
Old Aug 7, 2006 | 02:09 PM
drifter23's Avatar
drifter23
Default Motordyne 5/16 Spacer Question?
Just wanted to know if, anyone that has the 5/16 Motordyne spacer. Has encountered any dirty particles or oil stains in the engine bay. As around the plenum spacer I am getting some oil stains and dirty particles. Is this normal..? Any feedback would be greatly appreciated.
Old Aug 7, 2006 | 04:16 PM
Interesting. Are you certain that the upper plenum is tight?
Old Aug 8, 2006 | 08:34 AM
drifter23's Avatar
drifter23
Yes, I used a torque wrench for all the bolts. And used their specific torque specs that came with the spacer. I just noticed this when I removed the Plastic engine cover.
Old Aug 8, 2006 | 08:35 AM
jondimellow's Avatar
jondimellow
You oiled your filter too much? and unevenly?
Old Aug 8, 2006 | 08:42 AM
drifter23's Avatar
drifter23
[QUOTE=jondimellow]You oiled your filter too much? and unevenly?[/QUOI
I have a Vortech Supercharger and the filter is very small. And it is not over oiled or oiled unevenly. So, I don't think that is the cause of it.
Old Aug 8, 2006 | 10:08 AM
Beeker's Avatar
Beeker
Check to make sure you didn't get a piece of the rubber that surrounds the oil cap stuck inbetween the spacer and the plenum. That would cause a leak which air and oil could escape from.
Old Aug 8, 2006 | 10:27 AM
drifter23's Avatar
drifter23
The oil cap rubber piece is not stuck between the plenum. I think I will just re-install the spacer with some silicon on the top and bottom spacer gasket.
Old Aug 8, 2006 | 10:32 AM
savvy's Avatar
savvy
let me know how that works, i'm getting spacer soon and would like to know how to fix it if that happens to me too
Old Aug 8, 2006 | 06:08 PM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
Its normal.
A synthetic oil based adhesive is used to stick the gasket to the plenum spacer. When the spacer is bolted down by the plenum, some of the adhesive can squeez out.
It won't do anything though. If it gets dirty, you can clean it off with gasoline, toluene or other similar solvent.
Old Aug 9, 2006 | 08:18 AM
drifter23's Avatar
drifter23
Originally Posted by Hydrazine
Its normal.
Thanks, for the info Hydrazine.
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
