k&n typhoon install problem
Old Aug 9, 2006 | 07:36 PM
jcfox79's Avatar
jcfox79
Default k&n typhoon install problem
hey I just got a k&n typhoon intake and installed it today, but there is one problem. The mas sensor wire in kinda short so its a really tight fit where it plugs into the intake tube and im afraid its gonna get pinched. anyone have this problem?
thanks
Old Aug 9, 2006 | 07:46 PM
mickey99us's Avatar
mickey99us
yup i had that problem but i manipulated it alittle and it worked out fine. ill get a pic up in a bit
Old Aug 9, 2006 | 07:56 PM
mickey99us's Avatar
mickey99us
Old Aug 9, 2006 | 08:18 PM
jcfox79's Avatar
jcfox79
yep, thats how mine looks too, did we do something wrong? or is the design just bad? also do you know of this causing any issues with the mas? sorry for all the questions, thanks
Old Aug 9, 2006 | 08:59 PM
cvt's Avatar
cvt
that's how mine looks as well...i think it's just like that...
Old Aug 9, 2006 | 09:01 PM
sq40's Avatar
sq40
Same here, Mine is just like that. The Wire needs to be about 2 inches Longer for the "Best" position. But it works and causes no problems.
Old Aug 10, 2006 | 03:34 AM
Netko350Z's Avatar
Netko350Z
ditto here
Old Aug 10, 2006 | 04:56 AM
The MAF sensor line is tight. Remove the plastic engine cover. Is there a clip holding the line to the engine? Cut the clip.
Old Aug 10, 2006 | 01:52 PM
Mathys's Avatar
Mathys
Mickey, do you have some shots from you whole engine bay? So I can get an overall look with the typhoon installed.
tnx
Old Aug 10, 2006 | 01:54 PM
sq40's Avatar
sq40
Old Aug 10, 2006 | 05:20 PM
m1james@bellsou's Avatar
m1james@bellsou
sq40,
Looks good. What is your read on performance?
Old Aug 10, 2006 | 05:49 PM
Gary King's Avatar
Gary King
We removed the engine cover and then pulled the plastic clips, which hold the wire loom, from their mounts to get a little extra slack in the MAF Sensor wires. It took some persuading but we got enough slack to route the wires under the intake tube to give a cleaner look. Been running it like this for months with no issues and some of these days it was 100+ degrees out.
Here's a link to our website with some pics of the set-up:
http://www.gridesinc.com/Showroom.html#kn
Thanks,
Gary
Old Aug 10, 2006 | 07:31 PM
sq40's Avatar
sq40
Originally Posted by m1james@bellsou
sq40,
Performance is about on par with other Intakes, it is really noticable over 4K RPM. The Sound thouhg.. The Sound is incredible. No other intake gives you a Formula 1 esqe sound like the Typhoon.. None.
Old Sep 25, 2006 | 10:57 PM
type7's Avatar
type7
Can you use stock Z tube with the typhoon?
Old Sep 25, 2006 | 11:33 PM
Maybe but what would be the point. The Typhoon includes all necessary hardware.
Uriyo_
Sep 8, 2021 08:46 AM
