Larger MAF housing, Intake pipe and TB installed
Old Jan 28, 2007 | 11:45 AM
  #61
ACEMAN's Avatar
ACEMAN
Master
Originally Posted by tany009
come on aceman,what are you waiting for? im dying over here...lol
dying to see what a diffrence its going to make with a bigger mm setup on the dragstrip dyno. good luck.
To be honest, been putting all my money into my house. Remodeled the bathroom ( added corner tub and stand up shower ) and now im in the process of turning the actic into a master bedroom. Also setting up a baby's room ( little girl on the way ).
Its tough on the car being domesticated.
Later
Todd
Old Jan 28, 2007 | 11:52 AM
  #62
ct350z's Avatar
ct350z
im on a similar mission just without the baby. lol. congrats by the way.
Old Jan 28, 2007 | 01:49 PM
  #63
ACEMAN's Avatar
ACEMAN
Master
Thanks, she is due in MAY and will be my first.
Update on the larger MAF housing. Since i have installed the larger pipe and MAF housing, i have not had any problems. No cells or any issues with the car acting weird. I thought i might have little issues, but so far so good. I guess i did a OK job tuneing with the UTEC
Later
Todd
Old Jan 28, 2007 | 05:52 PM
  #64
Skrilla's Avatar
Skrilla
LOL I have 3 kids and go through the same thing. While I'm working in the garage evey once in a while one will come out and say what are you doing. When I'm finished giving my answer they look at me like I'm speaking german
Do you (or anyone) happen to know the ID of the upper plenum "neck" from the TB tp the lower plenum?
Old Jan 29, 2007 | 06:32 AM
  #65
Road Warrior's Avatar
Road Warrior
Later
Todd
congrats, but get your priorities in order...1 dyno 2 everything else
Old Feb 14, 2007 | 06:45 AM
  #66
vwpowa's Avatar
vwpowa
The Volkswagen guys have been running big MAFs for a while now. You can get a bigger maf and the proper size injectors and do no tunning and it will run perfectly (at least on a VW) Most guys dont do this for the hell of it for to reduce restrictions. But to go turbo. It makes it easier to get the tune correct with the factory ECU. They do this on cars built from 92 up until 2006. This includes cars that are normally aspirated and cars that come turbo from the factory. Here is something i copied and pasted from the vwvortex.com, the gentlemen who wrote this is a pioneer in VW tuning. He is one of the only ones that can create good turbo software for the vr6 engine (he does otheres as well) This info was done back in Nov 2001.
Take new injector size and divide by old injector size.
example: new = 448 cc/min, Stock = 224 cc/min
448/224 = 2
Now since flow in a pipe is proportional to the square of the diameter.
because volume flow = area * velocity.
(remember that area of a circle is [pi * radius * radius]
Take the injector size ratio above (2) and take the square root.
sqrt(2) = about 1.41
so I take the stock tube size (70mm) and multiply by 1.41.
New MAF size = 70mm * 1.41 = 99mm or to wrap it all up....
New MAF DIAMETER = 70mm * sqrt(new injector size / old injector size)
This will work for ANY size injector you want to install.
If anyone wants any other info i will try and dig up some stuff. I guess what i was getting at dont try this unless you have a way to tune it. You wont be dumping enough fuel with just a bigger MAF housing and stock injectors. Now if you did bigger maf housing and got the proper size injectors you wouldnt need tuning to have it running properly.
Old Mar 5, 2007 | 03:14 PM
  #67
__jb's Avatar
__jb
Z + Rear Seat
Small bump for a great thread...
Any updates?
Old Mar 5, 2007 | 04:44 PM
  #68
ACEMAN's Avatar
ACEMAN
Master
Any updates?
Nope, no updates. Waiting for the warm weather to show up again here in Maryland.
I will update this thread as soon as i get the results.
Later
Todd
Old Mar 6, 2007 | 10:59 AM
  #69
Road Warrior
looking forward to the results.
how is the car running aceman?
surprising how time flies
Old Mar 6, 2007 | 11:10 AM
  #70
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Car is running great now. But i did have to replace Ignition coil this week. Somehow i must of cracked the thing last year when i replaced my spark plugs. I guess with the cold weather it got worse and stopped working. All good now.
Yep, time does fly. I cant wait to get back to the track and try to beat my 1/4 mile time. Also, 2 more months and i am a dad
Later
Todd
Old Mar 6, 2007 | 11:20 AM
  #71
Road Warrior
Later
Todd
congrats to you aceman
seems like its always something....i need to get my car in soon for warranty work. i don't drive the car much in the winter so i will probably wait until this summer. my warranty expires this year already!
Old Mar 29, 2007 | 08:18 AM
  #72
ReavTek's Avatar
ReavTek
448/224 = 2
Awesome post. I'll definitely be doing this once some money is flowing in.
Old Mar 29, 2007 | 08:58 AM
  #73
1cockyZ's Avatar
1cockyZ
I remember one of the jdm tuners in that shootout of NA cars had a dual throttle body setup and the article said they just doubled the injector size cause with the twin throttle bodys and mafs it cut the signal in half. One of these days I am going to get my lazy *** to an infiniti dealership and see if the housing from a m45 or q45 will work with our sensor, and if its larger. I looked it up and the plastic housing is a separate part shouldn't be expensive. The coolest thing about a larger maf is the air friction or pumping loses are multiplied the further away from the port you get and besides the air filter the maf is the furthest away. I would love to see one of the people doing reflashes offer a larger maf and reflash combo. The pop charger has a good 5mm worth of meat to take out of the center. The stock maf necks down to 68~69mm at a point so a true 75mm would be nice.
for example 68.5/2=34.5 so the area of a 68.5mm throttle body would be 34.5^2*pi=3685mm^2
the area of a 75mm maf would be 75/2=37.5
(37.5^2)*pi=4417.86mm^2
percent difference in airflow
((4417.86-3685)/3685 )*100=19.89% roughly 20% area change for a 6.5mm change in diameter.
so basically if there is hp to be had aceman will show it and I can't wait.
Old Aug 1, 2007 | 06:22 PM
  #74
__jb's Avatar
__jb
Z + Rear Seat
Any news on this?
Old Aug 2, 2007 | 03:39 AM
  #75
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Any news on this?
Well, its still on the car and it still drives like a normal car
No dyno yet though. The life factor has kept me from the dyno, but it is still a plan of mine.
Need to find a larger Throttle body next.
Later
Todd
Old Aug 18, 2007 | 02:14 PM
  #76
KhanMan's Avatar
KhanMan
I thought people were running the Q45/M45/FX45 TB with out an issue? What about hte new VQ35HR TB is that bigger and will that work or the VQ37HR TB if ithat is bigger?
Old Aug 20, 2007 | 04:20 AM
  #77
Silo's Avatar
Silo
Chances are little that the HR engine's TBs are larger, since this engine type features two of them!
Old Aug 20, 2007 | 07:57 AM
  #78
Motormouth's Avatar
Motormouth
hey aceman, I'll pay for some dyno pulls if you get them done
Old Aug 20, 2007 | 12:22 PM
  #79
ACEMAN's Avatar
ACEMAN
Master
Thumbs up
Hmmm that sounds like a good idea
Todd
Old Aug 20, 2007 | 12:38 PM
  #80
Motormouth's Avatar
Motormouth
just let me know. maybe the dyno shop can even take my CC over the phone. or I can paypal/send money to you.
